Went to change greeting day and night and recording said I could not due to "message storage unit full". Meanwhile, there are no messages on this phone to clear. I would just like to restore this phone back and be able to reset it completely. Is there a way to do this?
SOURCE: "Waste toner tank full"message won't clear
I had the same problem with my printer. On the back of the waste toner cartridge is a tab that sticks out. A photoelectric shine thru this tab to let you know when the cartridge is full. My photoelectric had gone out and was giving the same error message. I took my printer apart and cut the wires loose on each side of the photoelectric and shorted them together to complete the circuit. The only problem in doing this is you have to occasionally check the waste toner cartridge yourself to make sure it does not overfill.
SOURCE: Blackjack Memory
ok this might work I cannot guarantee it. first back up all of your data onto your computer. After that turn off your phone. then first hold the up button then at the same time hold hold down the power button and you should get to format mode press 1 and it will automatically format it. then it should boot up normally. put the memory card in see if it works and put all of your data back on your phone. hpe this helps with your problems
SOURCE: recording
I have the same problem. I believe this unit is a lemon by Samsung. I was so exhausted I went to Hard drive erase. After I erased the HD, now it will not record or go into recode mode. I think all it good for now is just to view the monitor. When I call Samsung they dont have a clue what a DVR is. I never seen a company so illerate. They cant even tell me where I can send it for repair.
SOURCE: How to change the voice mail message on KP DCS - 24B LCD samsung
I have the manual for the DCS series and there is no help regarding this.
It does say how to turn from auto to manual and make sure that the time is correct.
1. If the manual NIGHT key is pressed BEFORE the system automatically enters night service then the automatic night service timer tables will be overriden until the system is manually restored to day mode.
2. If AFTER the system automatically enters the night service tables and will not be overriden.
SOURCE: samsung corby GT-S3653 how to change default message storage
how to change default message storage location in samsung corby GT-S3653 because it is showing sms memory full after 200 massages even it is having 500 storage capacity
- To Access Supervisor Options:
- From main menu, press 6 for Supervisor Menu
-Press 2 for Routing Box Administration
-Enter Box Number that you are changing / recording
(Main Day Greeting is box 800, Main Night greeting is box 801)
-It will repeat the number you entered and prompt you to press 1 if its correct
-Press 3 to Modify
-Press 1 for Greetings
-Press 2 to Record Greeting
-Press 1 to replay current greeting or Press 2 to record greeting
-Press * (star) for current greeting
-Record greeting.
