Plates -particularly on top shelf- are not cleaned properly on 30 deg wash. The top shelf itself does not seat properly as the height-adjustable plastic on the right would not take the highest position
Under the top shelf or in the top of the machine is the water rotor. remove this and ensure none of the holes are blocked, also ensure your macine is not running on 1/2 half load as this may only activate the bottom. it should be set to full load to use both. if rotor bloackage is the problem use somthing to clear it. and also check the bottom one. also remove and clean the inner filter as debris may have got past it and getting pumped to your rotors.
I hope this was useful
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
awqre
