Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Setting the date - Canon PowerShot SD300 / IXUS 40 Digital Camera
Posted by Ken Stork on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Follow the instructions beginning on page 31 of this manual.
Posted on Feb 15, 2013
Testimonial: "Exceptional ! Easy to follow and will be useful for any other problems which might arise. Ken Stork"
During setup an incorrect year and time entered. how do I reset them
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
Sep 29, 2018 | Time Computers & Internet
Setting time, date on power book g4
I'm taking it that you are running system 10 so go to system preferences under the apple menu, then go to date and time under System. Go to time zone and allow the time zone to be set automatically and then go to date and time and set the date and time automatically. If you want to set the date yourself you can uncheck the set date and time automatically and then select the date and then the time using the up and down arrows. Hope this helps.
Dec 06, 2012 | Computers & Internet
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
How do I set the date and time spamp on a Canon A490
Hello and Welcome to FixYa!
To set the date and time stamp on pictures, Follow the given instructions:
Setting Date and Time:
First of all set the exact and time if your camera:
  • Press the "Menu" button on the camera and use the right navigation button to choose the "Set Up" menu.
  • Scroll down to "Date/Time" and press the ""Func./Set" button. The set date and time will appear on the screen, and the month unit will flash.
  • Adjust the month unit by pressing the up or down navigation buttons. Move to the day unit by pressing the right navigation button. Use the same instructions to adjust each unit of the date and time.Push the "Func./Set" button to save the time and date settings.
Setting Date Stamp on pictures:
  • Press the "Func./Set" button and select "Recording Pixels" and "Postcard". The camera is now set to "Postcard" mode.
  • Open the "Rec." menu by pressing the "Menu" button on the back of the camera.
  • Highlight "Date Stamp" by pressing the down navigation button.
  • Change the "Date Stamp" setting by pressing the right or left navigation button. Your choices are "Off", "Date" or "Date/Time". Now, when you take photographs the date or the date and time will appear on the picture.
If this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 11, 2011 | Canon PowerShot A490 Digital Camera
How do you clear memory, and set date and time 712c
To delete all the records :
  1. Press the MEMORY button
  2. And while holding the MEMORY and the START/STOP button simultaneously for more than 2 seconds all records will be deleted.
To set date/time :
  1. Press the Date/Time Setting button to adjust the date and time (the year flashes on the display)
  2. Press the MEMORY button to advance by increaments of one year and press the Date/Time Setting button,
  3. Press the MEMORY button to advance by increaments of one month and press the Date/Time Setting button,
  4. Press the MEMORY button to set the current day and press the Date/Time Setting button,
  5. Press the MEMORY button to set the current hour and press the Date/Time Setting button (the time is set using AM/PM)
  6. And finally, press the MEMORY button to set the current minute and press the Date/Time Setting button.
Jun 14, 2010 | Omron Healthcare Omron Hem-712c 712 Blood...
Setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Feb 02, 2010 | Sharp EL-1197PIII Calculator
Current time and date samsung tocco lite
On the main menu select Settings, then Time & Date.
Set Time zone updating to Manual.
Then SCROLL down i.e. drag the menu upwards (this is the bit that many don't realise.)
Then you will be able to set the time & date.
Sep 20, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
How do i set the time on my nokia 2630
Select Menu > Settings > Date and time. Select Date and time settings to set the date and time. Select Date and time format settings to set the formats for date and time. Select Auto-update of date & time (network service) to set the phone to update the time and date automatically according to the current time zone. Hope it helped...
Aug 05, 2009 | Nokia 2630 Cellular Phone
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Jan 21, 2009 | Polaroid i830 Digital Camera
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select On, the phone will
automatically update the date and time.
Jan 03, 2009 | Cell Phones
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
