My CD player is not working and I would like to remove it and either have it repaired or replace it with a new unit. I would like to know how to remove it without having to take the entire dashboard out. Please advise. Thanking you in advance of your anticipated cooperation
One day the CD player in our 2005 Honda Odyssey just stopped playing. The radio works, but we cannot switch it to CD mode. I'd like to get it replaced or fixed. I'd also like to get all our favorite CDs out of it.
Almost identical problem in my '05 odyssey.Almost identical problem in my '05 odyssey.
AnonymousFeb 22, 2009
I have the exact same problem. Radio works but CD just stopped working. I just purchased a new unit on ebay and now need to figure out how to remove the broken unit from the van. I have the exact same problem. Radio works but CD just stopped working. I just purchased a new unit on ebay and now need to figure out how to remove the broken unit from the van.
I have the exactly same problem with my van. The CD player just stopped working one day, but the radio works fine. Would really like to know how to replace the CD player meself!
van.
radio works fine.
player meself!
Same problem, help, bought an extended warranty that doesn't cover a stinkin cd player.....Same problem, help, bought an extended warranty that doesn't cover a stinkin cd player.....
E00 is a vague error code used by Honda that indicates a problem with the CD Drive in the head unit. Unfortunately this will require removing and head unit and replacing it with either an OEM replacement or an aftermarket unit.
using a test light check the fuses in the fuse panel then check for power and ground at the socket. if one is missing remove the socket and check for power and ground at the electrical connector. if you have both the socket is bad and needs replacing. if you missing one you will have to check that wire to find were the problem is and repair it.
CD & DVD players are among the least reliable of all electronics and prohibitively expensive to repair because of the labor involved with removal and re-installation in a vehicle.Also, the transport mechanism that is causing your problem is not even likely to be available after 6 years.I highly recommend replacing with a new stereo and, if you are of faith, praying a little that the new one will last as long as the original.
All you can do without disassembling is pressing repeatedly the eject button while you turn on the unit at the same time. You can try first turning ignition off and on, then disconnecting the battery.
If that does not work, then the CD player must be pulled out and disassembled to access and remove the disk.
Try first turning on the unit and pressing repeatedly the eject. If there is no mechanical problem with the CD player that will work. If that does not work, then the player usually needs repair.
I've been looking for instructions to remove the stereo in my 2005 Odyssey as well. I found these instructions that should help: http://www.collegehillshonda.com/instructions/gen3_odyssey/musiclink.pdf It is actually for adding something else to the stereo, but there are instructions for removing the stereo there. You can easily find a kit that allows you to mount a standard car stereo in the space. You might also check out http://www.crutchfield.com Any stereo bought there comes with the necessary mounting kit and harness for your vehicle, as well as vehicle-specific installation instructions.
van.
radio works fine.
player meself!
I have the same jammed six disc changer problem in my 2005 honda van..
If anyone knows how to fix it please email me...
[email protected]
Would you be able to upload a photo of your dashboard's setup? If you can do that I can give you a definite answer almost immediately.
