SOURCE: rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
SOURCE: Problem for RCA L32HD35D 31.5 inch HDTV LCD TV
With a bright flashlight see if you can see a picture.. If you can this indicates your invertor board has failed. If not more than likely your main video board has failed. Ebay has tons of parts for these tv's.
SOURCE: Our RCA 32 inch TV L32HD35D has sound but the
No,Ur tv under a year old?Still under warrenty?Call RCA for warrenty repair.This problems is a major problems for the tv.The Tuner board it dead,must be replaced it cost u at lest $200 for a refurbish Tuner board.And u have to do the labors ur self.
SOURCE: 32 INCH RCA TV sound no picture
Check power supply to see if it is putting out the 24vdc needed by the backlight inverter board, you may have failed power supply or shorted out backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
