Question about Philips Sport Personal CD/MP3 Player
My mp3 will not come on after i charged it up
Posted by DAVID on
MP3 won't charge
My MP3 player won't charge or turn on [Solved] - CCM.net
ccm.net > Forum > Hardware
Jul 12, 2013 - Hello,Was charging my player, and all of a sudden it stopped. Now i cannot charge it and it will not turn on either, it's a Sansa Fuze. Please help ... Hipstreet mp3 won't charge!
Aug 23, 2015
Philips MP3 won't charge via mains USB
Jun 23, 2015
MP3 won't charge after washing
Sep 17, 2014
My laptop does not recognize my mp3 player [Solved]
Jan 18, 2013
More results from ccm.net
why won't my MP3 player charge? ' Yahoo Answers
Can u please tell me how to charge my mp3 player Laser 2G ? its new and they told me that it will be charged when i put it in my computer but i tried and i could not even while my computer is charging .
The MP3 player is charged using the supplied USB cable. When you connect the USB cable into the computer's USB port when the computer is switched on.
If the MP3 player still does not charge, try connecting it to a different computer. If it still does not charge then the USB cable may be faulty.
I suggest you take the MP3 player back to the supplier for a replacement. You should get them to test the MP3 charging.
4helpful
2answers
How do I charge the MP3 Player?
Have you got the cable that go's between the mp3 and the computer ?. If you have then that is haw you charge up your mp3 player, you can leave it hocked up to your computer while it is charging.
2answers
My mp3 won't charge
Check your usb cable if its ok, cos that's the major cause if your mp3 is not charging... or probably the battery cell is dead and cannot retain charge
How do i charge it
Three way to Charge you Battery...
1. Charge with USB Cable- Use usb cable and directly connect to you mp3 player, And another attach to the computer.
2. Charge with Charger - directly connect to AC power supply and another attach to mp3 player.
3. Directly Boost - Another way to charge, open your mp3 player and charge your mp3 battery directly (+/-) point with Zapper (zap gun) - It will boost your battery immidietly.
Charging mp3 player
If your MP3 has an inbuilt Li-Ion battery (e.g. no compartment for a standard/Ni-MH AAA battery), then connecting the player to your computer will normally charge it - this is the case for the PD-6070 'stick' player. Your player will also indicate that it is being charged (or not charged!) via the battery level/power indicator which is located on the top RHS.
Hope it helps!
Bought mp3 player and do not know how to charge it lost papers
there are a couple of ways you can charge you mp3 most people like to use the cable that comes with the mp3 and charge the mp3 through the computer. if you have already tried connecting your mp3 to you computer, then you probably need to install the software on the computer (you should have a disk that came with the mp3, but if not you can find the software for your mp3 on the web) after that your computer will recognise your mp3 and you should be able to charge your mp3.
Samsung MP3 not charging
Get the driver from:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=&dType=D&vType=L&mType=&model_cd=&menu=guides&prd_ia_cd=&acc_ia_fl=&disp_nm=YP-K3JAB&isEqualsY=Y#
12helpful
6answers
How to charge my mp3
make sure the power IS ON , before you put the usb cord in..that is the only way to charge it,,
1helpful
2answers
How to charge Philips Mp3 Player With WMA & IN-BUILT FM Tuner ?
Plug it in to your Pn usb and it should charge up that way
Philips Sport Personal CD/MP3 Player Logo
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
