Question about Generac Electrical Supplies
I installed a 14kw generator today and it burnt out all my surge protectors
Posted by j_overbey on
dennys23601
    Habit-Forming:
  • 80 Answers
DID YOU HOOK IT UP FOR120 VOLT OR 240 VOLT
Posted on May 22, 2014
Trying to find what oil filter can be used in 14KW Kohler
what is the filter part number on the Generator now? Give that to an Auto parts place and they will cross it to what they sell
May 05, 2015 | Kohler Electrical Supplies
I have a 5000 watt 6250. Why won't it start my boiler?
A surge protector is for surges coming into an appliance, it will not help ins this situation. Check the specs on the boiler. I suspect that it needs more than 6000 watts.
Jul 29, 2014 | Coleman Electrical Supplies
14kw kohler propane generator-sometimes does not start, put battery jumper on and it starts. Battery is new, but had the same problem with the old battery.
The battery charger is defective, as you can start it by jumping it off means it is just a low battery. without it running measure battery voltage, it should be around 12V then plug the charger back in, it should climb to around 13.8B with a good battery. If not have the float charger checked.
Jan 25, 2013 | Kohler 14resa 14kw Home Emergency Backup...
Lightning struck my Bravia
your tv is shot ,im sorry to say that but its burnt
Jul 29, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
I had to unplug my tv today (actually the TV is plugged into a surge protector, so I unplugged the surge protector.) when I plugged the surge protector back in the TV wouldn't go on (acts as if its...
There should be a surge release button on the surge protector to bring the protector back to normal (should be red in color) Some surge protection devices have this option so just check if your s has it. If that is not the case than I think that you might have blown a fuse in your TV.Might just have to open it up and change the fuse within with the same ratings, but please be careful because do have high voltages so get an experienced technician to do this for you.
Good Luck.
G.
Jun 29, 2011 | Televison & Video
Have an fg5700ak runs ok but no power output what
Typical diodes are 10 amp for these. The stator and rotor both have VERY low resistance readings. The reading typically will be below that which will register MEANINGFULLY on the digital meters.
My generator had 10 amp diodes with surge protectors across them. One of the protectors shorted and generator output was zero. Mine is a 6KW diesel silent unit.
Replaced the diodes with 70 amp ones with surge protectors that have 20 times the energy absorbtion as the originals. Unfortunately this required some lathe work to make holders for the diodes and the surge protectors to ride on the rotor.
Used the light bulb trick to remagnitize it once diodes were replaced.
Nov 10, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Taco timers and Surge Protectors
Do they run at the same time? The two items consume
a lot of power. Check the voltage when they are turned on. If the voltage is below 90 Volts. The power surge at your Taco is great. Then, the surge protector could not
handle the current inrush that's why it's blown off. You
must install a surge protector that can handle the Taco
current inrush.
Sep 06, 2009 | Plumbing
Electrical Supplies Logo
69 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
