Printer was working fine now printing orange pic out replace cartridges still the same will print in black and white if grey scal is set
Follow these steps to clean the print head from the printer's control panel:
1. Make sure the printer is turned on but not printing, and the red
b error light is off.
If the red light is flashing or on, you may need to replace the ink cartridge.
2. Press the down button to highlight More Options, then press OK.
3. Use the up or down button to highlight Head Cleaning, then press OK.
4. To begin cleaning, press OK.
While cleaning, the printer makes noise and you see a progress bar on the control panel
display. Cleaning takes about 30 seconds.
Caution: Do not turn off the printer or interrupt the cleaning process.
5. When the cleaning is done, run a nozzle check to confirm the print head nozzles are
clean.
Make sure letter-size plain paper is loaded in the printer, then press Stop. The nozzle check pattern prints.
6. If the pattern has gaps or missing dots, press Stop to clean the print head again.
If the nozzle check pattern looks correct, press OK to finish.
Note: Run nozzle check at least three consecutive times. If you do not see any improvement and you have replaced the ink cartridges, your product may require service.
SOURCE: prints grey not black
if the printing preference is on "draft", it will print everything on light color or grey. check the printing preference, choose text or image instead of draft.
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is
full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and
look inside carefullly with a flashlight. You will see a tube (down and
to your left) coming from the cleaning pump and it will have an open
end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this
piece of tube. Bring it to the outside of the printer, thru the access
panel.
Find yourself a suitable container
(Tupperware or a plastic cup or jar) that is not too tall. Put the tube
into this container and secure the tube and container so they won’t
come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
SOURCE: Epson Stylus Photo 1400 Prints Dark Shadows Red!
Did you use Epson Genuine Cartridges? ????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
