I have lifted up the front of the range and now the front two burners do not ignite
SOURCE: my maytag gas range has
Peace,
ngafm here at your service,
How old is the range ?
You may have some food that spilled into the burner and it could be causing the gas not to fully flow out of that burner so
it will come out with force.
If you have sealed burners and the cap and burner where the gas comes out, is removable by hand without tools!
You may want to check the gas holes in the removable burner is clear and or clean them out if they are clogged.
How old is the range?
I hope that these measures will help you remedy the problem simply and easily!
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
SOURCE: Maytag Gas Oven top burner does not turn on when in bake mode
That is the way it works. If you have an convection oven then they both work in bake mode but they alternate between the two.
SOURCE: Model MGR4452BDB range top burners work but oven
The igiter is bad and needs replaced . The glow bar has a crack and is not getting hot enough to open the oven valve allowing it to ignite.
SOURCE: I have a Maytag gas range model #CHG9800BAB. The
It is confirmed by you that therre is no gas flow .
So this is the critical missing link to the fault.
We must trace the flow of the gas from the front regulator valve . So using a good air jet, if you can get compressed air to blow into the pipes , it will be helpful. so open the gas inlet and check flow till the valve. Now check the flow from the valve to the ovenflow pipe.
if there is no air coming through use a thin wire to puch in for removing dirt / rust.Blown it out.
Check if the nozzle jet is blocked in the valve assembly through which the gas comes in. USe a thin needle to clean the jet.
Once you have established a clean flow of air , put back all the removed parts and connect the gas.
It must work for sure..
SOURCE: my Maytag kitchen range left front burner does not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
