SOURCE: my dvd player keeps coming up in black and white
sounds like the video processors on the input are bad
SOURCE: plasma tv problem
may i know, how the bar are inside the tv? You can use this link to see whats the problem is, http://www.fastrepairguide.com/plasma-tv-pdp-information/how-to-describe-explain-the-plasma-tv-problem-or-sym.html After you read this article, now you will know what's the problem of your plasma tv.
SOURCE: Hyundai LCD TV HLT 3010 Pictue suddenly turns black but has voice
This is quite a common problem on LCD televisions.
It is not a fault you can repair yourself unless you are a competent electronics engineer.
One of the transformers on the inverter board will be the cause as the tend to go open circuit. Being surface mounted adds to the dificulty of changing this item as well.
SOURCE: Hyundai Hpt 4240 Plasma Screen tuning instructions
Try the Hyundai web site, or call their service rep.
Jerry G.
SOURCE: Hyundai 42" Plasma TV
hyundai hpt2450 tv switches on with standby button on remote or at tv and picture and sound ok but the little "tv" symbol at bottom of screen remains on locked in tv mode.It is not possible to change channels alter volume or change input source! The set does not respond to the remote or on board controls.It cannot be switched back to stanby with either the remote or the sets own standby button. It has to be switched off the the main on/off switch.
Any suggestions?
