Cnet CWR-854 does not work
You may be advised to use an RJ45 LAN cable to try the following, then use the wireless connection when all ais up and running.
The default Login ID and Password is ?root? with password ?1234?.
This Wireless Access Point?s default IP address is 192.168.1.253,
You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision.
Note: you can also hold down the reset button on this Wireless Access Point?s panel for more than 10 seconds to reset its default settings back to factory default.
If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
