1994 Lincoln Town Car Logo
Posted on Feb 10, 2009
Wiper quit on 99 signature series ford
First the wiper moter was slow, with a groaning sound, the intermittant quit. would only wipe in fast speed then it quit altogether, also a clicking sound was heard during all this time.
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Feb 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
Helped
9684
Points
88
Wiper motor gone 375 dollars for repair happened in my 92 licoln towncar cartier
2006 fiesta. Front wipers . Intermittent and slow wipe don't work , fast speed does ?.
hi think you need a new motor as the control module is built into the wiper motor
1helpful
3answers
Wipers only work on fast. Checked the relay and its good, checked the switches and its good. What else needs to be checked?
This is (obviously) a two-speed motor. The low speed winding is burned out. Replace the motor.
Wiper control problem.
Lift up once: results in one swipe
Pull down to position 1: results in intermittent wiping
Pull down to position 2: results in constant slow wiping
Pull down to position 3: results in constant fast wiping
Wipers; no parking function, no slow speed, no intermittent function. All other functions OK.
the wiper moter has a module on it and when they go bad it will do what yours is doing. i would replace the wiper module and it should fix it.
1helpful
1helpful
Wipers won't stop wiping.
Sounds like your intermittent wiper circuit is defective. Normally the intermittent feature is engaged by one of the functions on the multi-function switch (usually on the steering column). The circuit of the intermittent wiper periodically activates a relay that closes across the "Wiper On" switch. Your intermittent wiper circuit is likely defective and holding its relay closed (or the relay is stuck closed), thereby keeping the wipers on. Note: The wiper motor has an internal switch that opens when the wipers are in the park position and that is designerd to stop the wipers in the park position. When you turn on the wipers (or the intermittent relay is closed), the motor's internal switch is shunted such that the wiper does not stop at the park point of the cycle.
Intermitent Wiper does not work
the most common cause of this is the wiper switch.
2answers
Wipers only work on fast speed no intermittent or slow wipe
The common way of controlling wiper speed is to use a 'tapped' resistor that supplies reduced voltage to the wiper motor on all but the fast setting.
They have to dissipate a good bit of heat and are subject to failure; I think yours has done that.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
