Question about Element Electronics Televison & Video
My Element Electronics ELDFT406 TV constantly turns off
The Tv is brand new. My son received it as a Christmas gift. I tried the sleep timer, that's not it. I doesn't have a cable cord or antenna connected to it. It does have a Roku box and an xbox connected to it. I was thinking maybe because we don't have it scanned for channels it's tricked to think its not being used, but it will turn off mid-game or movie. I can not get in contact with them to ask what is going on. Can anyone help me please?
Posted by Erica Hernandez on
5 Related Answers
Anonymous
SOURCE: LG 42LB5DF Horizontal lines when first turning on
I got my main board replaced under warranty and this fixed the problem.
Posted on Apr 25, 2008
Anonymous
SOURCE: i connected my (element electronics tv fl-3210)
take baseball bat and hit,hit,hit
Posted on Apr 24, 2009
Anonymous
SOURCE: Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
Posted on Jun 03, 2009
Mick
  • 325 Answers
SOURCE: LG 32LX3DC 32 in .Model
Hello Dupree71
The first thing I would do as its from a HOTEL is take the LG telly out of HOTEL MODE. follow the steps below, This should allow you to change the settings on the telly and store them. So when you turn the tv back on it will not revert back to the hotel Options
TV turned on. Hold down the MENU button on the remote for approx 5 seconds then type in 1105 this will take you to the LG hidden Menu.
in this menu there will be hotel mode turn this option off.
This will allow you to save your own setting without it jumping back.
When you follow my steps and its sorted for you please leave a thumbs up for me Please
Thanks
Little Dish Fitter
Posted on Sep 21, 2009
Anonymous
SOURCE: Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Posted on Nov 28, 2009
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
I can't get anyone from your company to respond to my pleas for help!!
Hello
I'm not expertised to give solutions to phone problems, yet let me give you a solution to your phones' problem. As far as it works well with speaker phone, the base unit has no problem at all. The problem should be at the contacts in the phone's socket. There are thin strip of connection contacts inside the socket, that connects with the handset. If these contacts does not get proper contact with thse pins of the handset cord, the fault you report here will occur even with a new handsset cord.
Just get this soket replaced. It is a replacable part. Most of the electronic spare part selling shops at your town will have this part. If you are not experienced to do this work, just get it repaired by any technician. A TV technician also can do this work. The fault is with its socket itself.
Just see, I'm expertised to provide solutions to problems related to TVs and DVRs. OK.
Jan 09, 2012 | Uniden Cell Phones
My son updated my 2g ipod touch on his (older?) computer. It is frozen now & won't go past a screen w/the itunes symbol & the usb plug. It will not restore. I have uninstalled & reinstalled...
  • This isn't an iTunes problem. While the iPod is displaying this logo, you need to plug it in to a computer that has iTunes open beforehand.
  • Try using another computer with iTunes installed, or another USB cable for the iPod. Try to restart by holding the sleep and home buttons for about 10 seconds.
  • If this still doesn't work, take the iPod to your local Apple store, where they can check for any hardware problems that may have occurred.
Jun 29, 2011 | Apple iPod touch
Sharp Model # 32C241 shuts itself off. When I unplug it for a few minutes and try again, it starts up and runs fine. Has happened twice this week. I'm disabled and money is an issue. What causes this and...
You could try and switch outlets and see if that helps. If it continues to do the same thing access the T.V. menu from your remote and check to make sure you don't have a sleep timer set. If there is no sleep timer and switching outlets doesn't help then my guess (from my own experience) would be that it's probably on its last leg and would require a repair. If it does require a repair then you would probably have better luck buying a new T.V.
May 03, 2011 | Sharp 32C241 TV
Hello,i have a new sony BX2D Bravia tv for my son and a new PS3 , ive found an old immaculate amp/receiver Sony STRDB940 I used to use ,how can i connect it all together so my son can have great sound for...
Just plug the Red,Yellow,White into the receiver in one of the inputs. Doesn't really matter which one they are labeled just to keep it easy to keep track of.But for ease lets do video one. There should be two sets within the video one input. Put the PlayStation on the set to the right and then run the identical red white yellow from the tv to the set on the left within the video 1 box. Tune your reciever to the Video 1 channel and then the tv to what ever input you have it on probably video 1 as well and your son will be good to go.
Apr 17, 2011 | Audio Players & Recorders
My rc car stopped working after 3 mins of play time. i put new batteries in and still not working. my son got it for christmas. there is a paper that says if u have problems go to [email protected] 1628.com but...
My son receive a Christmas present a remote control car and it doesn\'t turn....... I emailed the [email protected] 12 days ago and they have not responded...... this is a crappy way to do business
Dec 24, 2010 | Parents My First Rc Car
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
S2000 sound rocker
Go to this site you will get all the answers you are looking for. As for th cables you need to get the proof of purchase.
http://pyramat.custhelp.com/cgi-bin/pyramat.cfg/php/enduser/std_alp.php?p_accessibility=0&p_redirect=&p_lva=&p_sp=&p_li=&advsearchmode=0&p_new_search=1&p_search_text=s2000
Good Luck and Please Rate FixYa!
Dec 28, 2008 | Pyramat S2000 Sound Rocker for Xbox
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Televison & Video Logo
944 people viewed this question
Top Element Electronics Televison & Video Experts
Mike
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
