Question about Dell OptiPlex GX270 PC Desktop
Install windows 95 from floppy - Dell OptiPlex GX270 PC Desktop
Posted by Travis House on
Brian Sullivan
  • Dell Master
  • 27,725 Answers
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Posted on Feb 13, 2013
What is the hardware specification of windows 95
System requirements for installing Windows 95:
  • Personal computer with a 386DX or higher processor (486 recommended)
  • 4 megabytes (MB) of memory (8 MB recommended)
  • Typical hard disk space required to upgrade to Windows 95: 35-40 MB The actual requirement varies depending on the features you choose to install.
  • Typical hard disk space required to install Windows 95 on a clean system: 50-55 MB The actual requirement varies depending on the features you choose to install.
  • One 3.5-inch high-density floppy disk drive
  • VGA or higher resolution (256-color SVGA recommended)
Oct 22, 2009 | Microsoft Windows 95 for PC
There was a problem installing this hardware
Access: www.eMachines.com
Search for your type of computer (desktop/portable),
your series (T-----), and your model-number (Txxxx)
and you'll be able to download "drivers" for your specific system.
Sep 10, 2009 | Digital Research UNIVERSAL SERIAL BUS/USB...
Need to install operating system on laptop with no cd rom or driv
I believe this model of laptop was designed for Windows 95, which can be installed using only floppy disks. That would be just about your only solution. I would not recommend trying to install XP or anything on it, due to the outdated hardware. If it has a PCMCIA Slot on it (most do) you can buy a USB adapter that goes in there. But, as I stated before, I would just install Windows 95 on it (or possibly 98SE) Good Luck!
Dec 08, 2008 | Twinhead SlimNote N12PI Notebook PC
I cant install my canon BJC-4100 printer
What OS are you trying to install it on, and how are you getting the files? The printer came out when Windows 95 was brand new, so using the original installation discs (floppies?) on any newer OS is not going to work. Canon has drivers available online for Windows NT, 95, 98 and Me here.
If you have a newer Windows 2000 or Windows XP use the drivers that are built in to the OS. From the Add Printer option, select Canon as the manufacturer, then look for Canon Bubble Jet BJC-4100.
If you have Windows Vista, this printer is not supported in that OS. Nor is this printer supported in any Mac OS.
Jul 28, 2008 | Canon Office Equipment & Supplies
USB external floppy drive
In windows XP and later the USB mass communication driver are in built, so you can use these devices like USB Floppy drive, USB HDD, Memory card, flash memory etc...
But before windows XP Microsoft did not supply the driver for USB mass storage devices. So, in your case you have to install the Driver for your USB Floppy drive, then you can use this drive as Floppy drive but after complete boot of your Windows 95.
If any problem or more question Just Ask me
Thanks
Iqbal
Apr 07, 2008 | HP Compaq Business Notebook NX9010
3.5 Floppy drive
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp. all discs should be compatible, unless you took it from a apple machine for example. did it work when you put in a new floppy drive? all the best John
Feb 21, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Can I get the software on floppies?
A CD-ROM would initially be required to create floppy installation disks. This option will require 6 disks for Windows 3.x, 9 for Win 95, 98 and NT or 8 disks for a Mac installation.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Dell OptiPlex GX270 PC Desktop Logo
155 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
