Cable button blinks 5 times after i push each button
SOURCE: cox cable remote made by motorola - need code
In reading the manual I did not see that you could program the blank buttons to support a function like that which would be nice. These are for "tune in" However the pdf file: http://www.uei.com/images/uploaded_images/UEI_Cable_AtlasDVR.pdf
states that you can program specific/special device functions in learning mode but the manual does not cover this "learning mode" as it is optional on the remote
Here you can find more information on your Remote including the manual and factory tec support
http://www.urcsupport.com/
Lisa I hope this was helpful
SOURCE: "Select" button doesn't work-Cox universal remote for XBOX 360
Depending on the specific remote, some buttons may not work with all systems. HOWEVER, in many cases the things you thing the "select button" would do, are done by the "play button" instead (IE: That's how I have to select DVD menu options with my remote).
If that is not the case with you, you can try a different programing code.
Testimonial: "I tried that it didn't work. And I tried the programming codes that I found online for the exact same problem but a comcast remote instead of cox."
