Question about Hunter Dsp600 Alignment Rack/lift
Has anyone had problems with their Hunter alignment rack
Ours broke
Posted by draschka3 on
Jud Stephens
Me too don't know how to get my car down
Posted on Jun 07, 2020
John Kopischke
    New Friend:
  • 17 Answers
Yea mine has the green light starts blinking then the rack wont do anything
Posted on Jul 28, 2015
Why have all the plastic tabs that hold the top rack to the rack height adjusters broken off?
Poor design. Check with a local appliance parts supplier and/or Samsung for repair/replacement options.
Sep 21, 2015 | Samsung DMT800RHS Dishwasher
Hunter wheel alighment rack RM. What does it mean when the green light flashes?
Hunter Wheel Alignment Lift Repair Manual - Vckystxx.com
vckystxx.com/taggedby/hunter-wheel-alignment-lift-repair-manual/
Hunter Alignment Lift Rack Manual Pdfsdocumentscom, Hugh Dixon Hunter AlignmentLift Rack Manual.pdf ... For Hunter Wheel Alignment Lift Racks. ... Repair ...
Jul 28, 2015 | Cars & Trucks
My steering wheel is upside down.
things like that usually are not covered after fitting the rack take it for allignment
Apr 13, 2017 | 2007 Nissan Murano S
Where can I find replacement blades for my Hunter fan 28072A
Not sure if this will help but I replaced a set of blades by lining up a used set and drilled new holes with an electric drill. They are still working after three years.
Jan 29, 2018 | Dryers
Steering wheel wiggles from side to side under
Bring the vehicle to a repair shop that has a Hunter wheel alignment rack. They will tell you what your suspension needs and do the correct alignment.
Sounds like tires and ball joints, possible control arm bushings . I need to do visual inspection and know make , year and model of vehicle to give a fairly decent diagnosis of your problem.
Jun 23, 2010 | Dodge Ram 1500 Cars & Trucks
Inner tie rod has come out twice - - 94 honda accord wagon
Yes, replace the rack. Estimate, no way anyone can tell you this. Shop around and get quotes on racks and fitting if you do not want to undertake this yourself.. Make sure you have a wheel alignment after the new rack is installed if the workshop does not do this or if you replace the rack yourself..
Dec 01, 2009 | 1994 Honda Accord
Glass replacement for Hunter fan
Hi, hunter fan glass replacement can be found at amazon, take a look here and chose: Amazon com hunter fan glass replacement. Regards. Donald
Jul 10, 2009 | Hunter 52" Ceiling Fan With Light And...
Air and heat have both been running on Hunter 44155C
There should be a switch on the thermostat.
AC-OFF-HEAT
And another switch
FAN ON-OFF-AUTO
Normally, you just set it for heat or AC and set the fan for auto. If it isn't wired correctly, the switches won't make any difference. It will either run all of the time or not at all.
Feb 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter Dsp600 Alignment Rack/lift Logo
2,234 people viewed this question
Top Hunter Hoisting Experts
AZBen
AZBen
Andrew Taylor
Andrew Taylor
gbob59
Are you a Hunter Hoisting Expert? Answer questions, earn points and help others
