Question about Toshiba 55H70 55" Rear Projection Television
Disassembling 518h3 need to take apart my Toshiba 55H70 55 in. Rear Projection Television. Any video or picture help would be amazing
Posted by RJ Gregory on
Mark McDaniel
    New Friend:
  • 4 Answers
I have the same set. I have not found any videos online as of yet, but hopefully this link will help.
http://www.doityourself.com/forum/entertainment-center-tvs-stereos-vcrs-dvds-8-track-tape-players/296524-broke-toshiba-55h70.html#b
Posted on Feb 27, 2013
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: 65 Toshiba picture sides are bowing in.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Feb 21, 2008
Anonymous
SOURCE: Television Problem
I have just run into the same thing, prior to the picture not coming on there was a loud whining noise, I thought it was the fan in the back, but, what I tried was removing the lower back panel, LIGHTLY tapping the light wheel assembly just left of the Bulb housing, and using a shop vac to first, **** the assembly around the edges and then reversing the air and Blowing it out. After much dust and dirt flying around the TV came on. It now only makes a little noise now and then, but, I will try this again today and then put the back panel back on. Since it would probably cost as much as a new TV for the color wheel, I gave this a try. For now, it is working.
Mr. Wizard
Posted on Jul 21, 2008
Chuck
  • 108 Answers
SOURCE: toshiba 42h82 - "broken" picture
the "scan converter module" is located directly behind the board where your inputs are in the back of the set. That should repair the problem.
Posted on Jan 08, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: toshiba 61 inch rear projection scrambled picture
If you are seeing lines and or noise for the first several minutes and it goes away--I think I know what the problem is.
Has the period of time before it clears up been getting longer and longer?
Reply to me with the exact model number and I will tell you what is wrong and what has to be done to fix it.
A lot of these sets have problems with what is called a HYPER board----it controls all signal inside the set--confirm Toshiba and exact model number---
I am here to help people and I do this here for free.
REGARDS, SD TECH
Posted on Oct 31, 2009
Testimonial: "Very useful and considerate. thankyou"
Ecollier2012
Edward
  • 3459 Answers
SOURCE: TOSHIBA 42PW23P rear projection television
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
Recycle Projection tubs
The fluid is probably glycerin
The lenses are glass
The tubes are leaded glass
check your local best buy
toshiba has a take back program
and
http://search.earth911.com/?what=Television+Accessories
Jan 19, 2015 | Toshiba 43HX70 43" Rear Projection...
Disassembly
should unscrew from the back of the tv and slide out , just make sure you un plug tv and wait 30 mins before taking it apart , and be careful with the mirrors as if they get moved you wont have a good picture
Nov 05, 2013 | Toshiba 57H94 57" Rear Projection HDTV
Hi, our toshiba rear projection tv will turn on but no picture. whats the problem? thanks
MODEL NUMBER 56H80 TOSHIBA PROJECTOIN TV,PICTURE IS NOT COMING AT ALL
WHATS THE PROBLEM
Feb 04, 2011 | Toshiba 57H81 57" Rear Projection...
Toshiba rear projection television
this problem is solved from your remote or from your kit,, first u confirm from your remote setting,,
Apr 06, 2010 | Toshiba 42H81 42" Rear Projection...
Need to get an old toshiba 50" rear projection out of basement...do they come apart?
on most rear projection tvs there are two screws that hold the mirror in the back portion in the out position they are normally located on the flat part of the back next to the curved plastic they are removed and the mirror is hinged to fold in to allow to fit through doorways if that is the problem if weight is the issue they can be dismantled farther would reccommend
take digital pictures or vedio to allow you to put back together if you are going to reuse
Dec 10, 2009 | Toshiba 50H81 50" Rear Projection...
This is jeff I just received an answer to my problem with my Toshiba 57H82 57 in. Rear Projection HDTV. The answer was " Try Wathing the Picture in Picture " But I don't know what Wathing Means
srry . watch the picture in picture . the sub video path takes a different route through video processing and may look ok. the pip control button should be at the bottom of the toshiba remote.
Oct 02, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 46h84 rear projection shutting down
I have a Toshiba 46h84 with similar problem that needs a new green crt. Mine does not have a cooling fan. I don't know if having a cooling fan would help the problem, but mine didn't come with one. There are rear projection TV's that have bulbs in them that require a fan. This particular model uses a red, a green, and a blue crt to generate the picture and probably doesn't need one.
May 19, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 50H72 rear projection TV. NO Video
Bad caps and solder connections, especially in around the 9v regulator just about center of the defection circuit... Not a terribly expensive job and certainly worth the repair if the cabinet is in good condition...
Bill
Jan 13, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
