Question about LG LMV1813ST Microwave Oven
LG microwave - does not heat food. Light is on, turntable turns, you can hear the fan and the magnetron. Called LG help line and they said it is probably door latch. How do I fix that?
Over the range model. Purchased 11/2011. Installed and in use since 3/2012. No extended warranty purchased.
Posted by Toni Crummett on
5 Related Answers
Anonymous
  • 50 Answers
SOURCE: Will not heat.
Hi I've been out of the microwave repair business for a few years now, but the technology has remained virtually the same as far as I know. You obviously have some knowledge of them, as you know about the safety switches in the door. Microwave ovens are actually a very simple device, to test it, put a coffee cup of water inside, and set the unit on high for one minute. A second or two after you hit the start button, you should hear a fairly loud "bong" noise, and a hum that continues untill the time runs out. That noise is the magnetron starting up, and if that noise does not happen, then the magnetron or related circuitry is probably bad. NEVER open up the oven, as the magnetron may be charged, and must be discharged by a technician. If the sounds that I described are present, then the water should be boiling or close to it in one minute, if not,then something I've never seen has gone wrong. Assuming you had a year warranty on it, I know from experience that if you contact Goldstar customer service by phone, or letter, they will often extend their warranty a month or so to keep happy customers. Its worth a try. Hope this helps you out. P.S. Never operate a microwave without something inside (Non metalic)
Posted on Nov 30, 2006
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: LG Microwave Oven LMV2053SW
That's common - it's a problem on your control panel. We regularly repair these control panels for only $32.50 nationwide. For critical safety info & detailed disassembly info, see our link in our FixYa listing here: http://tinyurl.com/yzjozk Let me know if you need further help. I appreciate your kind rating!
Posted on Jan 28, 2007
Anonymous
SOURCE: my LG microwave does not heat food ,spins but makes noise
high voltage fuse blowed
Posted on Oct 27, 2008
ZZ10952
  • 17 Answers
SOURCE: Microwave Magnetron tube has arced
REPLCE THE MAG TUBE AND ***
Posted on Feb 08, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: LG Microwave does not heat food
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
GE microwave model # JES1855PBH 04 .This was purchased less than a year ago. It just stopped working.Will not do anything,does not even light up controll panel.
First, check your circuit breaker to see if the circuit may have flipped off. If it isn't off...
Lucky for you that this item has a one year warranty. Look at the second to last page of the instruction manual and follow those directions. If you bought it using a credit card, have the receipt and the original manufacturer's warranty is out, call the credit card company and ask them if you can make an extended warranty claim. They will usually double the manufacturer's warranty.
Jan 15, 2011 | GE Microwave Ovens
Hello I am not havingany problem.I need to activate ,my danby microwave warranty.
Go to this link:
https://www.danby.com/registration.php?ln=CE& (copy and paste)
If you have purchased an extended warranty you will need to go to this page to activate the extended warranty.
https://www.danby.com/warranty.php?ln=CE&tip=EXT
Thanks for choosing FixYa.
Kelly
Sep 20, 2010 | Microwave Ovens
I have a Samsung SMH 8165 ST that just quit. It
If the oeven was only purchased ij August it will be covered by manufacturers warranty, just check the air intakes are clear of debris first though.
Hope this helps
Jan 07, 2010 | Microwave Ovens
Can't find my receipt to verify warranty coverage
warranty starts from the purchase day not manufacture date
your bank statement is proof of purchase as it has the date , the amount and where you got it from
Mar 05, 2017 | Whirlpool MH7140XF Microwave Oven
How do i get extra warranty
An extended warranty is normally offered by a retailer at the time of the sale. With some products such as cars, computers, and televisions, there are companies that will sell you an extended warranty as long as you purchase it before the manufacturer's warranty runs out. There are a few manufacturers that will sell an extended warranty to an owner of their product, but, once again, it has to happen before the original warranty runs out.
Contact the manufacturer and ask if they offer extended warranties. If they don't and you're still within their warranty, visit the link below. They offer extended warranties of 4 and 6 years for appliances.
http://www.doityourself.com/icat/extended-warranties
If you feel this solution doesn't deserve a good rating, please let me know why. If there is anything more I can do to help, I will!
Feb 04, 2009 | Danby Microwave Ovens
Vent motor turns on, but does not draw air in as it should...
the vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Jan 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave dmw1148ss
Usually you must purchase the warranty within some specified time of the purchase, such as one week.
But your best bet is to contact the dealer where you purchased the unit. If they are able, they will be eager to sell you an extended warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | Danby DMW119 Microwave Oven
I purchased a GE Microwave from Wal-Mart 03/23/'07 at the cost of $103.20. Wouldn't you know one month after the 1 year waranty is up it won't heat. It makes a sound louder then normal and more of a...
I junked it and will never buy another GE product. The repair people cost more per hour and that was their advice also. I purchased another microwave with an extended warranty. Lesson learned.
Apr 24, 2008 | GE Microwave Ovens
LG LMV1813ST Microwave Oven Logo
258 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Nick Olsen
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
