Question about Konica Minolta bizhub Office Equipment & Supplies
Reset image unit (Magenta) Konica Minolta Bizhub C352
Hello, The copier asks me to replace the imaging unit magenta. My question is: Is it there's a possibility to reset the chip or the imaging unit magenta Konica Minolta Bizhub C352 on. thank you SAFAR
Posted by Safar on
  • Adorjani Laszlo Feb 16, 2013
    Enter in service mode:press following keys:Utility-Meter count-Check details-Stop- 0 - 0 -Stop - 0 - 1 - Stop - 0 - C touch IU life stop setting -touch NO STOP.The copier displayed in continuity the change iu message,press OK and you be will work,the copier dont stoped.
Adorjani Laszlo
  • Konica Minolta Master
  • 1,316 Answers
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Posted on Feb 14, 2013
1 Related Answer
Anonymous
SOURCE: My konica bizhub c350 copier is printing a double
we provide best service in konica all color machines contact me 9871565085 rajesh negi delhi
Posted on May 11, 2010
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 19, 2015 | Konica Minolta bizhub C250 All-In-One...
Malfunction C2553
Open close front door to reset. But your Magenta Image unit is having issues remove and shake the unit side ways to spread developer and toner whole length of the unit. Worse case get a new magenta image unit.. Also clean the sensor below the image unit when pulled out all the way near the front of the copier each color has one except black.
Mar 22, 2015 | Konica Minolta Konica Bizhub C250 Copier
I have konica minolta bc 250 its giving error c2553 pl help me
hello it is a image unit problem.
You got your toner/developer ratio out
Magenta will be low as we know.
Then while still in service mode run TCR supply
Re-check ratio % you should be OK
Change magenta image unit
Feb 28, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
What s error code c-2554 of konica minolta bizhub c253?
C 2554 Abnormally high toner density detected Magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
Aug 06, 2013 | Konica Minolta Bizhub C253 Copier
Image ghosting only on magenta
If the ghost is only on the magenta, your imaging unit is to blam.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 08, 2009 | Konica Minolta bizhub C250 All-In-One...
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
1,316 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
