Signal strength keeps flashing
SOURCE: 2 Wire DSL Wireless modem range expander
you might want to try to change the wireless channel 1. open your internet browser 2. type on the address bar 192.168.1.254/management or 172.168.0.1/management and press Enter 3. type your system password (modem password) 4. go to home network -> wireless 5. change your wireless channel to 9 - 10 if after changing the channel it still wont work please check for EMI (Electro Magnetic Interference) such as electric appliances, hallucinogen lamps, WIRELESS PHONES, satellite dish and or alarm systems. also make sure that you dont put your router on a carpet. usually a good distance between your router and the computer is around 5 - 20 feet with no walls between them since walls also contribute on the interference. one last note, keep your router away from water i.e. aquariums, water dispenser and the like since water contributes to the interference of the wireless signal
SOURCE: signal strength keeps varying
if you arent in a clear line of sight, many things can affect the signal strength of your network including the thickness of the walls, the composition of them and anything else that may be in the way. if you use a 2.4 ghz router and you have a 2.4ghz cordless house phone, they can interfere and cause issues. A microwave oven that is located between the router and a device can cause interference as well.
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
SOURCE: I can't connect my wi-fi to my ipod touch. My
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
SOURCE: no signal for wireless. Trying to get onto Ipod
1.You will need to add the device to the router in the wireless access. this is done by MAC(Media Access Control) address of the device to be used.
This done be logging on to the web gui using 192.168.0.1 or 192.168.1.1 ( consult your user manual for the proper IP address.
2. check your instruction set for the device to see how to link it with a router ( should be in your installation instruction)
3. On the PC go to the command line and type "cmd" this will bring you to the DOS prompt the type at the prompt ipconfig /all >>> this will let you know all device that are connected to the router.
SOURCE: The router often looses wi-fi signal and dhcp
Here are some links for things to look for and check for you wireless connection isues:
If the links do not work just copy and past them in to you browser. If you dont have a internet connection available I have listed them below the links.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=172c1dae41534ddd818c560b60c7c230_4029.xml&pid=96&slnid=16
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=efc03a44a5bb47bd804cf4d0eb3015c8_Top_Causes_of_Intermittent_Wireless_Connection_to_a_Linksys_.xml&pid=96&slnid=16
Top Causes of Intermittent Wireless Connection to a Linksys Router
There are three key reasons that may be cited why the wireless connection between your Linksys router and your computer is intermittent or is experiencing timeouts.
i. You have a low signal quality received from your wireless router.
ii. You are experiencing signal interference from other wireless devices.
iii. Your router's firmware needs to be upgraded.
You have a low signal quality received from your Linksys wireless router.
The location of your wireless router with respect to your computer greatly influences your connection to the wireless network. For a better signal quality, it is ideal that the wireless router is placed in a central spot of your house or on a location free from any obstruction blocking its range.
To determine the signal quality received from your wireless router, you must connect to the wireless network first.
NOTE: For instructions on how to connect wirelessly to your Linksys router, click here. If you're using a Mac computer, click here.
Once connected, check the signal strength received by your wireless adapter or Airport for Mac users. The recommended signal strength should be closest to full bars to have the best connection possible.
The frequency used by your router's wireless network may be 2.4 GHz, 5GHz or both. Some devices may also be using the same frequency and this causes the interference to the wireless network of your Linksys router. The most common examples are cordless phones, microwave ovens and baby monitors. Another possibility of frequency interference is that there may be other wireless networks in the area. Your frequencies may be conflicting with each other.
To solve this, turn off the device that is possibly causing the interference or relocate your router away from it. Another solution is to change the current wireless network channel which is set in your router's settings. For instructions on how to do this, click here.
If you are having unstable connection and have confirmed that the previous causes are irrelevant, then you may have to upgrade your Linksys router's firmware. For instructions on how to do this, click here.
Encountering Intermittent Wireless Connections Using a Router
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. We suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
1)To change the router's SSID or the wireless network's name, click here.
2)To change the router's channel, click here.
3)To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, it could mean that your firmware is corrupted. For instructions to reload or upgrade firmware, click here.
