I am trying to hook up a pro form exercise bike, and i am being asked if my router is DHCP enabled and if a firewall is turned on. Please advise
SOURCE: Router doesn't obtain WAN IP address (DHCP)
you can hook the router up and go into the settings by when it is hooked up to your computer, type in http://192.168.0.1 and the password is usually user or admin. the password is usually password, unless it was changed. you may be able to change settings to fix this problem through that GUI
SOURCE: 3CRWER100-75 no DHCP IP on child routers
router 1 (base) router 2 (repeater) router 1 (base) is the network, the SSID is where u get your internet connection set router 2 with same SSID, DHCP on. i advise connecting hardline to make sure both routers are working correctly. once thats verified then go wifi
SOURCE: trying to access my 2wire router
Please try the following:
1. Check the ip address and default gateway on the computer by typing ipconfig in command prompt.
2. Try to ping the default gateway from the hardwired computer.
3. If you are able to ping the default gateway, but not able to log in, Delete Cookies and check if you could log in.
4. If you still could not log in, try from another web browser.
SOURCE: how do i configure my ip address manually for 2nd
Have you tried simply running the Network Connection Wizard from control panel? Here is a link to a basic guide. I'm not sure I understand whether there's an issue with the connecting computer or if you want to set up a host/client shared connection. If the latter see here. Does this apply to your situation?
Take a look at this post, and also see the FAQ sections of the same site for endless help.
You can also access 2wire tech support here.
If you think there may be some corruption in the 2nd computer, run chkdsk according to instructions here and here.
You might also have a look in the Device Manager and make sure the network adapter is working properly. It will show an exclamation point or question mark if it's having problems.
Your connection is behind the 2wire firewall, which should be turned on. If you mean your system firewall, OK for now...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: why does my belkin g wireless modem router f5d7634
You said that the Internet connection is dropping. It is a modem *** router.
If there is any MTU settings , then reduce the MTU.
For example If MTU is 1500 then reduce it to 1400.
Otherwise you will need to upgrade the Firmware of the router.
Click Here for more info about the networking
