Jenn-Air JCD2295HES Side by Side Refrigerator Logo
kipp Posted on Feb 13, 2013
Refrigerator sound like it has a cricket in it
1helpful
Do I have a 20 pound cricket behind the refrigerator??
That's the compressor. Check the compressor mounts to see if they are cracked, loose, or have hardened or broken rubber bushings. Also check to see if the compressor housing is improperly touching something that transmits its vibration and acts like a sounding board. Sometimes there is a problem with freezer icing in high humidity conditions, leading to ice buildup on the refrigerant tubing at the compressor (excessive running) - this makes the tubing insulation rigid and things get really noisy. The fix is to shut everything down, let it defrost, and clean out the defroster drain tube.
If you can't find anything like that, you may have something going out in the compressor. If possible, make an audio recording and play it for a service technician at an appliance shop - he may be able to identify exactly what the problem is.
My smeg fridge is making a constant cricket sound noise constantly
first check for a cricket
if no cricket is found, it's likely one of your 2 fans. one will be down by the compressor and the other is inside the freezer compartment.
The part thats mounted inside on the wall sounds like theres crickets in it
There's probably crickets in it, someone may have forgotten to seal the refrigerant/drain line hole from the exterior of the home.
1helpful
Samsung refrig fan noise-sounds like cricket.
sounds like the bearing is starting to get tight in the fan motor. i would replace the fan motor.
1helpful
Ge compressor makes cricket sounds while running
yes from what you've said it is the bearings if there not bad then there on there way. good luck
Ice maker vibrates and gives no ice
check filter of water supply.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
