Question about Car Audio & Video
This may seem very basic, but what is bluetooth?
Posted by roger nori on
donnie jones
    New Friend:
    Problem Solver:
  • 8 Answers
Bluetooth is a wireless technology standard for exchanging data over short distances from fixed and mobile devices, creating personal area networks with high levels of security. in your car, it allows you to answer and speak on the phone hands free
Posted on Feb 13, 2013
How to use bluetooth wireless headphone with alcatel smart phone?
There are a lot of alcatel phones. Do you have a model number? Basically, you go into the menu or settings, find the bluetooth menu and press "pair". Press and hold the power button on the bluetooth headphone until it "beeps".
The phone will ask for a pairing code, typically 0000. Try this or get me a model number of both the phone and bluetooth. Good luck!
Jun 11, 2017 | Alcatel Radio Communications
How do I get a pairing code for a HYPE Ultra Slim Bluetooth Keyboard?
Pairing code for keyboard is not usually required. The one I have basically has a connect button, then you confirm on the computer. Otherwise the most common pairing code seems to be 0000.
Dec 01, 2014 | Hype Technology Ultra Slim Bluetooth...
User manuals free downloads
Hi. I may be able to help you, but I will need more information. Specifically, which device are you trying to pair to your iPhone? I assume you're talking about Bluetooth, right? You can use Bluetooth devices with your iPhone, including headsets, car kits, stereo headphones, or an Apple Wireless Keyboard.
To specifically answer your question, I would need more information about what you are trying to pair with your phone. Note that the documentation that came with your device (headset, car kit, etc) should contain instructions. Is it a Plantronics that you're trying to pair by any chance?
Also, from the title of your post, it appears that you're trying find free manuals for your iPhone. You can access the iPhone Manual from this site: http://support.apple.com/manuals/
If that link doesn't work for you, just go to www.apple.com, click on the Support tab located in the bar at the top of the screen, then scroll all the way to the bottom of the page and look for Manuals under the Resources column in the rectangular "Support" box at the bottom. From the new page that opens up, select "iPhone User Guide -- For iOS 7.1 software." You can download the manual or simply view it. It is very long! Bluetooth Devices are located in Chapter 3: Basics, page 35. BUT, the manual doesn't really tell you anymore than what I've listed below.
Here are some basics, if that is all you're needing:
Turn Bluetooth on. Go to Settings > Bluetooth.
Connect to a Bluetooth device. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. See the documentation that came with the device for information about Bluetooth pairing. (For information about using an Apple Wireless Keyboard, there are different instructions.)
iPhone must be within about 30 feet (10 meters) of the Bluetooth device.
More basic instructions are here:
Return audio output to iPhone. Turn off or unpair the device, turn off Bluetooth in Settings > Bluetooth, or use AirPlay to switch audio output to iPhone. See AirPlay on page 34. Audio output returns to iPhone whenever the Bluetooth device is out of range.
Bypass your Bluetooth device. To use the iPhone receiver or speaker for phone calls:
Answer a call by tapping the iPhone screen.
During a call, tap Audio and choose iPhone or Speaker Phone.
Turn off the Bluetooth device, unpair it, or move out of range.
Turn off Bluetooth in Settings > Bluetooth.
Unpair a device. In Settings > Bluetooth, tap next to the device, then tap "Forget this Device." If you don't see the Devices list, make sure Bluetooth is on.
Aug 06, 2014 | Apple iPhone 5c
Does my Neo Basic B3363N has a Bluetooth function?
In the specs it's not listed but in Control Panel do you see a bluetooth icon? In your search box type "bluetooth"?
Nov 28, 2012 | Computers & Internet
How do i turn on bluetooth with a htc wildfire
Bluetooth basics Bluetooth basics Bluetooth is a short-range wireless communications technology that allows devices to exchange information over a distance of about eight meters without requiring a physical connection.
Turning Bluetooth on or off Turn off Bluetooth when it is not in use to conserve battery power, or in places where using a wireless device is prohibited, such as on board an aircraft and in hospitals.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Select or clear the Bluetooth check box.
Mar 05, 2011 | HTC Wildfire Cell Phone
My bluetooth fails
ur bluetooth ic needs to be replaced
Aug 05, 2009 | Nokia N95 Cellular Phone
I have a sony ericsson cell phone , and a motorola hs850 bluetooth and cant seem to get it to connect to my cell phone, can you help dee
make sure booth phone visibility are turned on and try then to pair ur devices. it should work. if it doesnt, consider that one of the phones can only transfer basic things like contact cards etc (motorolla i reckon!) hope this helps
Sep 09, 2008 | Cell Phones
Acer 5580 Bluetooth and USB port problem
There may be a bent connector on one of the USB ports or a defective USB controller on the motherboard. The bluetooth connector may not have been reconnected or the bluetooth module was not reinstalled after service. Sadly you will need to have it serviced again. They most likely will not replace it it with a new laptop, but maybe a refurbished one. You could push for a warranty extension for amount of time the system has been due to need of repair. Good Luck.
Sep 07, 2008 | Acer Aspire 5580 Notebook
About my vista home basic
Check in the device manager to know whether the drivers are installed.
The issue would be bcause of the drivers.You can install the drivers using the drivers cd which you shold be having.
You can also use this
Start / Programmes / Camera Assistant. No idea who the software publishers are.
Whether or not this software is running, You can start the webcam using the [Alt] - [F7].
Bluetooth :
Try to enable it using key combination FN+F8.
You can download the bluetooth software from here :
http://aps.toshiba-tro.de/bluetooth/
Good Luck.
Live, Love, Laugh.
May 07, 2008 | Microsoft Windows Vista Ultimate Edition
Sony TXN17P Bluetooth vagaries
Hmmm...
If you can connect manually but it is not connecting automatically, then you have a settings problem either on the phone (less likely) or within the applet on your laptop controlling the bluetooth services. Try that first before reverting to the XP bluetooth software; usually when companies include custom bluetooth software, it is necessary.
If you cannot connect at all...
If you have tried to pair the laptop with the Nokia using the Toshiba applet and it never seems to work, and you've tried adjusting the settings on the phone and in the applet, and you know the bluetooth card is on and running normally on the laptop, I'd suggest uninstalling the Toshiba drivers and software through CONTROL PANEL and then rebooting and see if XP takes control of the bluetooth adapter. If not, try uninstalling the bluetooth hardware in DEVICE MANAGER and then rebooting, which will force XP to do a clean install (including bluetooth support software) and see if this gets you to normal operation under XP. If not, go to the SONY web site and, again, do a clean install of their bluetooth support software for your model, and try again from there. One of these combinations is pretty sure to work.
Make sure that if your laptop has a physical button on it to activate the bluetooth radio, that it is on, and that the device is enabled through device manager/network/connectivity. Any one of these being mis-set can (especially on Sonys) result in a confusing set of inexplicable failure conditions.
Good luck...
Nov 17, 2007 | Computers & Internet
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
