I have a Toshiba satellite L655 and it's not turning on with charger if battery is removed when i plug in the charger LED shows and if i press the power button the charger LED light goes off and then the charger and power LED lights comes on but nothing els comes on not the CPU fan or HDD or LCD display nothing the charger LED is white and the power LED is orange. Please can someone tell me what can i do to solve this problem please email me at [email protected] thanks.
SOURCE: my toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
SOURCE: Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
SOURCE: NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
SOURCE: Samsung R40 laptop does not turn on.
You have a failing PMU on the motherboard it is like a sister bourd allowing the system to function nomatter what the situation this is fatal if not resolved i recommend a service center
Testimonial: "Thank you for this."
SOURCE: how to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
