Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Turn off ecm
SOURCE: my panasonic uf-595 says on the display to replace
Ok, on this machine there is a battery accessible to you. It is either on the doc feed cover towards the back - you'll look near where the paper feeds in and you will see a panel that you can slide out to reveal the small watch type battery OR it's on one of the side panels towards the rear - sorry but I have not seen these machines for years but used to repair them at panasonic everyday and this is common. The battery only keeps memory of your telephone numbers when the machine is switched off - nothing serious - it will not affect your machine's operation.
Posted on Jul 08, 2009
SOURCE: I have a Panasonic Panafax UF 595. Battery error
The battery case is next to the small blue lever where the document is placed to fax out.
Posted on Feb 16, 2010
SOURCE: How do I turn off ECM on my Panasonic UF-490
press function
press 7
press monitor key 4 times slowly
* "start button"
should say service more
press 1
press 20 then start
press 1 for invalid / off
then press start
then unplug and plug back in the machine
Posted on Jul 14, 2010
SOURCE: Panasonic Panafax UF-585/595 prints 5"
It sounds like the fuser unit is on its way out. The cost to fix may out way the price of a new one. You should bring it in to a certified Panasonic repair centre to get a quote though. Fuser units are worth about $300. It could also be a failed toner. Try taking the toner cartridge out and gently nock it back and forth to free any stuck toner.
Chris
Posted on Aug 15, 2011
Feb 16, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Jun 05, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Feb 09, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
Nov 27, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Sep 21, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Jan 22, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Apr 23, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Apr 17, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Jan 08, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
69 people viewed this question
