ALL of the other inputs work with no issue. When I try using any device; computer, cable box, streaming player, ect...., the TV "power Cycles". It turns on and off repeatedly; never enabling me to use the HDMI inputs. Dave Hammons [email protected] 615-480-5786
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
SOURCE: DVI warnings when you connect HDMI cables
TV IS IN DEMO MODE GO IN OPTIONS MENU OF VIDEO AND TURN OFF. READ OWNERS MANUAL PAGE 80,81,82
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
SOURCE: LG HDMI problem
have you found the solution for this problem because i have the some problem with my tv??
