Question about Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv
Need a wiring diagram and parts list for model #c46535 champion generator
Need oil level sensor
The generator shuts off after 30 minutes with an oil level alert but oil level if full
Your oil level sensor is bad. It needs to be replaced. If you unplug the wire leads to the sensor you may get the generator to run, but you'll have no low oil level/pressure protection. The oil level sensor is on the engine crankcase usually near the oil level dipstick. You'll likely see a small sensor with a couple of wires attached to it. To replace it, you'll need to drain your engine crankcase before removing the sensor.
Apr 06, 2014 | Kipor RV Generator Sinemaster IG3000
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Aug 02, 2012 | Champion 3500/4000 Watt Portable Generator
Unit just shuts off after about 15 minutes of operation
Hi and welcome to FixYa, I am Kelly
This may very well be as simple as having to make sure the generator is sitting level and the OIL level is fully serviced. The generator has a low oil level sensor. The Subaru / Fuji Heavy Industires EH and EY series engines seem to be very sensitive to oil level. I can tell you from owning one myself and from my 40 years of experience. I replaced my oil level sensor and in a few weeks was experiencing the same problem all over again. I finally disconnected one of the wires from the low oil level sensor and resigned myself to checking the oil and servicing the oil to full each time I added fuel. (It works for me)
There are other things that can cause this symptom. Without your exact model number I can not look it up and make other recomendations at this time. If you still have the problem first try disconnecting ONE wire from the low oil level sensor after making sure the unit is fully serviced with oil. Then see how long it is before it shuts off. (If at all!) Once you disconnect the low oil level sensor you MUST check and service the oil if necessary each time you add fuel.
Should the problem persist respond here with a COMPLETE model number and I will help you.
Thanks for choosing FixYa,
Kelly
Aug 31, 2011 | Coleman Powermate Subaru 5000W Portable...
After unboxing and setup genpower 305 will not start
The generator has a low oil level sensor. Make sure the oil level is FULL all the way to the point oil comes out of the oil fill port when you add oil. If after your sure it is full of oil it still does not start then disconnect ONE wire from the oil level sensor and check for spark.
There is a model number on a data plate that begins with "PM" like this:
PM0435005
This model came as a manual and an electric start so the model number is important. The engine on this model is a Subaru engine and my experience with Subaru engines it that the low oil level sensors are extremely sensitive to even the slightest drop in oil level. (Good engines though!)
There should be a fuel selector that you need to turn ON and a Choke lever that you PULL and then push in upon start.
This should be and EH34 or EY34 engine.
Kelly
Aug 28, 2011 | Coleman Powermate Premium Plus 6250W...
Powermate 5000er 10 hp won't start no fire to the plug
Make sure that the generator is full of oil. It has a low oil level sensor that will ground the spark if the oil is low. If you have filled it to FULL with oil and still have the problem disconnect the low oil level sensor (one wire) and check for spark again. IF you now have spark the oil level sensor has either failed or is dirty. (yes you can clean them with carb cleaner.)
If after doing the above you still have no spark... I need 2 things.
1. the actual model number off of the generator Will start with PM or PMO
2. the engine model number / type / series number off of the engine
Kelly
Aug 27, 2011 | Coleman Electrical Supplies
Low current. Will hardly drive a sander or lights. Voltage guages says 120V. Unit is 3 years old but has maybe 10 hours of use max
I found this at http://www.championpowerequipment.com/tech-bulletins/
AVR Voltage Adjustment
This bulletin covers the following Champion Power Equipment models:
C46535 C41150 C41365
C46540 C41155 C75520E
C49055 C41255 C71350E
Note: Read instructions completely before performing service.
1. On the end of the generator locate the round yellow cover held on by two 7mm bolts.
Remove the two bolts and the yellow cover will come right off.
2. At approximately 7 o'clock you'll see a kidney shaped electrical component called the AVR,
which is held on by two 7mm bolts. Remove the two bolts but do not disconnect the wiring
and turn the AVR over so you can see the backside. You should see a round part coming off
the AVR, this is the capacitor. You should also see a small rectangular box with a jewelers
screw, this is your voltage adjustment screw.
3. With a flat head screw driver turn the jewelers screw counter clockwise and this will lower
the voltage. As the screw is turned back watch the volt meter to see adjustment, the
generator must be running to do this.
4. Adjust the screw until the meter reads 250 volts. On model C46540 when the toggle switch
is turned to the 120 side the volt meter should read around 130 volts. Optimum voltage is
121.8 volts.
5. If voltage does not decrease or does not hold a steady output please contact Champion at
877-338-0999 for a new AVR.
If you have any questions, please contact Champion Power Equipment:
Champion Power Equipment, Inc.
10006 Santa Fe Springs Rd.
Santa Fe Springs, CA 90670
Phone: 1-877-338-0999
Email:
[email protected]
Jul 02, 2011 | Champion International Champion Power...
My Champion 6.5HP Generator has a gas leak under the gas tank. The gas shut off valve is missing a rivet (one of two). I've got it unscrewed but am not sure how to get a replacement part. I have the...
They have a website at http://www.championpowerequipment.com. Click "support" and they tell you "If you need to order a part please call our tech support line. Our professionally trained technicians will be able to assist with placing orders. Orders ship within 1 business day - orders received before 2:00 PM (PST) will be shipped same day." The number is 1-877-338-0999. They also have many service bulletins thee thay will help solve many problems.
Apr 23, 2011 | Champion International Champion Power...
PF 2500 watt generator... Need plug and oil
30wt oil, probably a Champion RN4C plug. Could give link to a manual if part / model number of generator was provided.
May 17, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
I need the wiring diagram for the model 40026 generator
Go here:
Champion Power Generators : http://www.cpeauto.com/techbulletin.php
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 08, 2009 | Electrical Supplies
Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv Logo
605 people viewed this question
Top Champion International Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Champion International Electrical Supply Expert? Answer questions, earn points and help others
