What cables do i need to connect the 2 tv and dvd player an how do cnnect them
You need a set of normal rca cables (red.yellow,white) and another single rca cable..
OPTION 1 :If you have a digital satellite receiver, Connect the 3 colour cables to the corresponding colour jacks on VIDEO 2 of your dvd player to corresponding colour jacks on the VIDEO OUT Of your digital satellite receiver...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 2 STRAIGHT TO TV: connect the 3 colour cables directly to the corresponding colour jacks on the SIDE of the tv...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 3 IF YOUR PLAYER HAS AN OPTICAL INPUT: if this is the case you can just connect a single optical cable to the optical ports on your player and tv and this will enable the sound from your tv to play through your dvd player as well
SOURCE: Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
SOURCE: I have bouight a samsung home theatre system that
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
SOURCE: I want to connect an external DVD player (Samsung
yes u can connect an externel dvd player to your sony dav s 500...
you have
composite video input X 1 and
analog input X 1.
so you can connect the RC output pins of externel dvd player to the input of composite video and analog left and right audio inputs to the SONY DAV S500.
ANY QUIERIES MAIL TO ME
[email protected]
kanny-sounds.blogspot.com
SOURCE: Connect iTouch or Ipod nano second generation to Sony S500 home theatre system
DVT721 USB will not work keeps searching would like to play music using i-pod, blackberry, or memory stick
