SOURCE: Computer to Denon via Monster Headphone cable to V.Aux (Front) RCA inputs
Are you using a stereo-mini to RCA cable that has a red and a white RCA plug? What I mean is, you should have the one cable coming out of the headphone jack on the computer, and two (left and right) cables going to the receiver. The only other thing I can suggest is making sure the cables are tight. Maybe try another input on the receiver. There really shouldn't be any feedback unless there is some underlying problem.
SOURCE: Denon AVR-3300 Center Chanel Sound Problem
My guess is You have dried out electrolytic capacitors causing failure. These receivers when they get over 6 years old start drying out fluid in capacitors especially on regulator p.c.b. causing noisy supply lines. I work for Authorized service center in Michigan If you need repair and Shipping to Michigan is economical let me know [email protected]
SOURCE: Connecting DVD player to AV receiver
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
SOURCE: Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
SOURCE: No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
