Question about Sharp AQUOS LC70LE847U 70 Inch Quattron 3D 1080p Smart TV LED LCD HDTV
Error code C208-U4-L1173) comes on the screen when i try to access text
No tele-text error c208-u4-l1173
Posted by maureen Patterson on
  • maureen Patterson Feb 14, 2013
    The fault happened when i turned the power off by the mains i can not access the tele-text on sky BBC1 the fault number above comes on the screen and i can find no fault number the same on-line the TV is a Sharp smart Led 70 inch
How can fix error u4 code in xerox photocopier machine
http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
How to unfreeze a samsung c208
hi you can get the unlock codes from here
http://www.mobileunlocksolutions.com/samsung-c208/rs1wp9/
and the instructions about how to use the codes from here
http://www.mobileunlockguide.com/samsung-c208
10helpful
2answers
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 • Cell Phones
3helpful
2answers
8helpful
3answers
Fuser error code u4
You would have to replace the fuser to resolve that code.
Help me for error code u4 for xerox 5921
The U4 codes for Xerox machines are for the fuser (heat roller) unit. It's rarely something that you can fix yourself I'm afraid.. Sometimes it pops up from overwork and powering off the machine allows it to cool down but if it keeps coming back you need to get it checked out properly..
4helpful
2answers
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
8helpful
4answers
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Sharp AQUOS LC70LE847U 70 Inch Quattron 3D 1080p Smart TV LED LCD HDTV Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
