Tascam Pocketstudio 5 MP3 Player Logo
Question about Tascam Pocketstudio 5 MP3 Player
Pocketstudio 5 getting started?
HiTi P110S PocketStudio Photo Printer does not work with Mac 10.7?
Apple has a habit of dropping older printers with their newer operating systems. Check the printers website for a solution and maybe try the driver from a newer model.
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
My tascamm 388 wont turn on Is there anyone who works on those in wilmington nc 28403?
Check the fuses.
Take off the cover above the VU meters and look inside to the right.There are a bunch of fuses.Check to see if any have blown.
PocketStudio 5 Error - encDSP Init Err
I turned off the unit, then while holding down rew and record buttons at same time, turned on unit. I don't know why, but it worked.
1helpful
Pocketstudio 5
A CF card is a compact flash memory card. It's rectangular and has two rows of holes along one side which fit over the connector pins when you slide the card into its socket. Compact flash cards can be bought from electronics or photographic shops, and some department stores. They are not expensive but these days they are usually 1Gb and up. The TASCAM Pocketstudio 5 can only format up to 128Mb so most of a modern card is not used but the card will still work.
Not recognized by computer
http://www.tascam.com/Products/PocketStudio5.html There is a menu on the left with all the documentation, as well as downloads of their software updates. This product is discontinued, so no further support will be available from the manufacturer.
3helpful
2answers
Compact flash cards
what is the solution for this problem posted by tiller on Sep 26 2006
Top Tascam Audio Players & Recorders Experts
Morne Olivier
Morne Olivier
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
