it sounds like someone has switched the gears of operation in your device. You would need to call 1-800-269-6215 to reach MT yard to send someone out to fix it . Otherwise, you could have a major accident. Thank you.
check your brake pins on the trany there rusted and sticking. you can also shoot some wd-40 and hit your bake pedal till ti comes loss. now if you still can't use low dear check your variable speed pulley assay. may need to be replaced or rusted too. check for missing spring too. adjustment may be needed
make sure the narrow side of the belt goes in the pulley; you may have the wrong belt; make sure all the pulleys for that belt are the same height , if one is higher than the others that may be the problem
