Question about Refrigerators
WHAT ARE THE OPTIMAL SETTINGS FOR THE GE REFRIGERATOR MODEL GBSCOHBXCRWW FOR FREEZER TEMPERATURE AND REFRIGERATOR TEMPERATURE
Posted by DON CARMEN on
daniel hendrickson
    President:
  • Refrigerators Master
  • 1,922 Answers
5 freezer and 5 for refrigerator
Posted on Feb 12, 2013
5 Related Answers
Mark
  • 13 Answers
SOURCE: GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
Posted on Jan 04, 2009
Amigaman
Gerald Griffin
  • 248 Answers
SOURCE: ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Posted on Nov 14, 2007
Anonymous
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
Anonymous
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
Anonymous
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
What should freezer setting be at
I suggest you to put it on freezer,make optimal temperature and chill :)
Mar 26, 2014 | General Electric GSH25JSXSS Stainless...
GE S-Series Side-by-side refrigerator
you ll change the temperature control unit,since its not performing optimally
.thanks and godbless
Sep 29, 2008 | Refrigerators
HOW TO SET THE FREEZER TEMPERATURE IN A GE MODEL GSS23WSTA
Hi!!
Go to this site http://www.geappliances.com/ in the Service and Support you'll find the information you need to set the temp in your Freezer.
Don't forget to rate this post!!
Sep 28, 2010 | GE GSS23SGSSS Stainless Steel Side by Side...
Variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Sep 04, 2009 | GE GSS20IEM Side by Side Refrigerator
My refrigerator is a ge profile bottom freezer is it normal that its verry warm in the back
Do you have your condenser coils at the back ? Yes it is normal - How much air clearence do you have at the back ? If your unit is fairly close to the wall there is not much room for the heat to dissipate properly - those condensers do get hot and radiate heat - it is important for your fridge to get rid of heat and critical to its cooling properly. Make sure the condensers are cleana nd not clogged with dust - if your ambiant room temperature is hot your refrigerator will work harder and you will feel it getting warmer at the back - check to see if your compressor runtime is excessive or not and make sure your cooling temps are in the normal range - Freezer no warmer than 10F (optimal at 0F and colder) and refrigerator no warmer than 40F, optimal at 34F.
Sep 04, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Fridge is warm, freezer works.
Smilar problem, but the model is GTH15BBMFLWW
Jul 16, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Ge artic refrigeratior freezer stainless steel
Unplug / Replug the fridge. If doesn't work might be the mother board in back.
Jul 13, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
247 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
