Touchpad and control buttons do not work,i keep hitting the F5 key and it tells me it is enabled checked out mouse in control panel and it tells me it is working properly, am using external mouse, this laptop is brandnew had win 8 installed then deinstalled professionally and came today from seller with touchpad initially working but left control button not working. after pressing f5 it stopped working all together
Try going to your Device manager and right click on mouse properties and click on the touch pad tab. If you look it probably has the touchpad as disabled. Sometimes this will happen when you use an external mouse. You should be able to unclick the box and change the field from disabled to enable. Its 99.9% of the time NOT your drivers just that the touchpad was disabled. I hope that helps
Contact seller. I'm a bit confused? Brand new Windows 8 install then Uninstalled ? Why? Is Win 8 still installed?
have figured out whats wrong , the drivers need updating , also they have installed a driver for a 32 bit operating system whereas the computer here has a 64 bit operatinng system. had win 7 put back on as i hate win 8 and want to delay having to use it for as long as possible, that's why it s not straight forward i reckon .
SOURCE: HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
SOURCE: Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
SOURCE: Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
SOURCE: Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
SOURCE: Touchpad and mouse buttons suddenly stopped
you did wrong things first ..
you needn't to download the driver as you are not sure of your model touchpad company. i think you have downloaded the wrong driver . first you have to knoew the company's name then go to thier official website thier check your driver version correctly. as you have a new system you needn't to download driver as they are installed when you buy it.
so try Roll Back Driver in device manager touch pad option after that ur touch pad works
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
Get online
and got to www.google.com In the google search box type: "Acer
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Touchpad drivers.
Some laptops don't have dedicated buttons but you can use Function keys (like Fn + F5 on Dell computers) to toggle the state of your touch pad. In the case of HP laptops, you can hold the top-left corner of the touchpad for few seconds and it will disable the touch pad - repeat this to re-activate it.
New laptop computers either have a physical on/off button to easily disable the touch pad or there's an icon in the system tray that lets you manage the various settings of the touchpad. If you don't have that icon, you can go to Control Panel -> Mouse Properties -> Touch Pad to enable or disable the touchpad.
The touch pad can also be disabled through the device manager. Type devmgmt.msc in the Windows Run box to start the device manager, expand "Mice and other Pointing devices", right-click and disable the driver entry that says Touch pad or likewise.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
