Question about GE GSL25JFXLB (250 cu ft) Side by Side Refrigerator
On setting 1(warmest) freezer is 14 degrees. thermistors are 32 ohm(defrost) and 30 ohm (bottom of freezer) and the defrost circuit resistance is 22 ohms(proper range)...there are no burning or burnt resistors on the main board. takes 2 days to defrost anything out of the freezer. thermistor for refrig side is in proper range as well
Posted by jeff on
daniel hendrickson
    President:
  • GE Master
  • 1,922 Answers
Your thermistors are way out of range even at that temperature you say,put each thermistor in a glass of ice water for 5 minutes,then remove the J1 connector from the main board and check with an ohm meter set on 20k ohm between the thermistors common terminal #5 and the other pin terminals all thermistors tested this way should be about 16k ohms when tested this way,if not replace them
Posted on Feb 12, 2013
Testimonial: "further inspection both freezer thermistors were bad. Refrigerator side was not defective. Thank You for your response."
  • daniel  hendrickson
    daniel hendrickson Feb 14, 2013
    hope alls well otherwise....cheers!!!
3 Related Answers
Anonymous
  • 531 Answers
SOURCE: refrig/freezer thermistor temp/resistance chart needed
by model# you can get it not all carry the same (temp)
Posted on Apr 07, 2009
caroldon
  • 17130 Answers
SOURCE: 22 cu ft. bottom freezer
It needs to be confirmed that your auto defrost timer is the main culprit.You will need to confirmt he wiring of the timer once again, the lines to the heater and to the cut off relay of the compressor starter. First of all the timer can be tested out , make sure that you mark the connections with the wires colours and see if the timer works fine. If so when the complettion of the 8 hours cycle( normally) the realy will trip for the auto defrost. So try to observe the working of the timer so that you know that it works. If so your defrost fault will be cured. Hope my advice helps . Good day
Posted on Aug 12, 2010
renegade-35
  • 492 Answers
SOURCE: Re: a GE side
defrost timer
Posted on Jan 24, 2011
Wont dispense water
look on eather top or bottom of hinge wear the water line goes in the door probably kinked
Jan 23, 2014 | GE GSL25JFXLB (250 cu ft) Side by Side...
Refrigerator not cooling
Many reasons for this, most of which you could not fix yourself.
Is the fan running in the food section? Is the freezer section cold enough or is the problem just the food section?
Repost your question with more information.
Oct 25, 2013 | GE GSL25JFXLB (250 cu ft) Side by Side...
The defrost cycle timer on gsl25jfxlb stays on, what can cause this and how can this be fixed?
If it's in defrost all the time the timer is stuck and needs replacing. If it's electronically controlled, suspect the probe (thermistor) that sits on the evaporator
May 20, 2012 | GE GSL25JFXLB (250 cu ft) Side by Side...
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
The refrigerator stays at 47 degrees but the bottom compartments freeze
You have a defrost problem. A blockage of frost in the freezer prevents air flow over the cooling coils there, allowing very cold air to migrate back into the bottom of the refrigerator section. Unload the freezer and remove the back wall, melt the frost off the coils with a hair blower, and check to see if the defrost heater at the bottom of the coils is burnt out. If heater is OK, replace the 1.5 inch long white thermistor located at the very top of the cooling coils.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The refridgeator just quit working compressor not coming on, freezer defrosted not cold all door controls work fine!
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | GE GSL25JFXLB (250 cu ft) Side by Side...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Dec 20, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE GSL25JFXLB (250 cu ft) Side by Side Refrigerator Logo
379 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
