Perhaps you'll have some luck here:
Kicker Product Owner Manuals
SOURCE: subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
SOURCE: wiring diagram
Are your Speakers dual or single voice coil? The best way to find a wiring diagram is look at the rockford fosgate web site. I ll give you a tip to keep in mind. when wiring the ohms of a sub when you wire it in parallel positive to positive and negative to negative on one speaker you have left it in 2 or 4 ohm configuration depending on speakers. When in a series the ohm load will change by wiring positive and negative together will give you a lower ohm the more speakers you add to the amp. Fosgate will let you see how its done
SOURCE: wiring
1st--on 1 sub put a wire connecting one red with white dot to the blk with white dot
2nd--do the same thing to the other sub !!do not wire a red/white to an all black
3rd--wire the full blk negetives to the amp, then same thing to the positive
SOURCE: i have a kicker L5 solo baric and a mono amp what
http://www.kicker.com/wiring_diagrams
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
