Question about Stanley Utility Knife
How to change blades on Stanley Fat Max 10-777
How do you change blades
1 Related Answer
Jeff Harris
  • 81 Answers
SOURCE: Have a Stanley Fat MAx
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
Posted on Jun 26, 2011
Yes I have a stanley fat max and I need a bulb Where do I get one?
I have a Stanley Fat Max but as it is a storage box, it doesn't have a bulb.
Mar 08, 2018 | Stanley Measuring Tools & Sensors
How do you change the blade in a Stanley fat max knife 789
Don't touch the blade by hand use a pair of pliers. There should be a screw in the center of the handle, just remove it and you will see how to remove the blade.https://youtu.be/pFnbiw88Z8c
Oct 18, 2015 | Stanley Measuring Tools & Sensors
How do i change the blade on the stanley box cutter fat max?
Push the blade out as far as it will go and hold in the button on the side while slideing blade in and out.
Apr 20, 2012 | Stanley Hand Tools
Have a Stanley Fat MAx utility knife and unable to open it to load the blade
Jun 26, 2011 | Stanley Utility Knife
How do you put blades in stanley fat max extreme razor knife
Not sure exactly because I don't own one, but the review seems to indicate you push the blade positioner all the way forward, and push a release to remove the old one out the front, and then push a new own in until it clicks in place. With the blade positioner all the way forward.
But the review said it did not work well.
http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Feb 26, 2011 | Stanley Garden
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I can't open or refill the fat max. Lost the instructions.
If it is a 10-816 then Knife swivels open for easy blade change and clean out - no tools required, much like 10-999
If it is a 10-778, you don't really open it. You press little button on left side, behind the blade wiper, and this releases blade. Push red button on rear of knife, to open blade storage
if it is a 10-999 then press the button on rear and rotate the two halves.
Oct 29, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Fat max laser is in inches need feet
Press and hold the "+ - units" button and hold for over one second. It should then let you select your units of measure. In this case it should be the second selection, which is "0.00 ft". If you lost your owners manual, you can download one at www.engineersupply.com/Manual-and-Help-Docs/Stanley-TLM100-Manuals.pdf. If you find this helpful, please rank the solution.
Mar 11, 2009 | Grip On Tools Stanley& Fat Max Tape...
Stanley  Utility Knife  Logo
712 people viewed this question
Top Stanley Cutter Tools Experts
efs_perpends
efs_perpends
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
