Question about HP PSC 1610 All-in-One Printer, Scanner, Copier
Scanning multiple documents into one pdf with a HP 1610 all in one
Scanning multiply documents to one pdf
5 Related Answers
Anonymous
  • 106 Answers
SOURCE: Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Posted on Jul 04, 2008
alvinbga
Alvin Barnabas
  • 136 Answers
SOURCE: Cannont scan to PDF or RTF with HP PSC 2410 All-In-One InkJet
You have a problem with your scanner software or your operating system.Try connecting you scanner to another computer, install the software, and try scanning.
Anonymous
  • 813 Answers
SOURCE: HP C6180 All-in-One - Scan to pdf
u need a software for it its a pdf writer
here is link 4u 1st u have to creat file u will be print for pdf printer
http://www.cutepdf.com/Products/CutePDF/writer.asp
Posted on Jul 11, 2008
Thomas F. Schneider
  • 2715 Answers
SOURCE: How to scan multi-page documents (text) into a single pdf file?
You are welcome.FIx Ya?
Posted on Jan 21, 2009
Anonymous
SOURCE: Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Posted on Oct 16, 2009
Hi I have a HP 2135 deskjet printer, scanner, copier. I to scan multiple pages if 'Scan PDF" is selected. I cannot get this to work. Does this little printer have this facility??
Have you installed the latest software version of HP Scan on your computer?
Heres a link to the HP instructions on how to scan multiple pages using the document feeder.
https://support.hp.com/us-en/product/hp-deskjet-ink-advantage-2130-all-in-one-printer-series/7174559/model/7174560/document/c03466081
7helpful
3answers
25helpful
How do i scan multiple pages
Please perform the steps given below to scan multiple pages to a single PDF file.
NOTE: Before performing the steps please make sure that Adobe Reader is installed on your computer. If not installed then goto www.adobe.com and install Adobe Reader.
  1. Open HP Solution Center.
  2. Click on Settings.
  3. Click on Scan Settings.
  4. Click on Scan Preferences and Select the option 'Prompt for additional scans when preview is turned off'.
  5. Click on OK to apply changes.
  6. Now Click on Home and click on scan Document
  7. Select Document to File under scan shortcuts.
  8. Uncheck the option Preview Scan at right bottom of the scan window.
  9. Now Click on scan to scan document.
  10. When prompted for additional scan place the another document on scanner glass or ADF and Click on Scan.
  11. After scanning is complete Click on Finish to save the scanned document
  12. To Locate the scanned document (PDF) goto My Documents folder and Open My scans folder.
1helpful
2answers
Cannot scan multiple pages
Somewhere within the software of your (or any other) scanner there usually is a place to "turn on" multiple scanning ....
I have a HP Photosmart 6180 series printer. I want to know how to scan multiple document of several pages or more and put into one file? Whenever I have scanned in the past, I have only been able to put 1...
To scan documents, you must choose the PDF scan. Need to figure out how to choose to scan as a PDF. That's in the software or scan buttons. In that setting, there should be a choice of single or multiple scans. After the scans, you choose finish and the program should show you a PDF document and then save to a folder of your choice.
I am using an HP Officejet Pro L7680 all in one. I am trying to scan multiple pages into one document. The list offered by my HP Solution Center for saving scanned documents is .jpg .tif etc. but each...
Well once you have digitized all the documents can they all be converted to PDF?
THen all you need to do is to make sure the titles are in numeric order as page 1 - whatever
Adobe PDF acrobat professional lets you place them all into one doc.
On the left open page options at the top of this menu you can insert after of befor all the rest of the docs just open the lead doc and then add pages to thea you will build a book
5helpful
hi,
SOLUTION I.
SOLUTION II.
Thank you.
adonscott
Don't want scanned JPEG, need PDF
Hi Choink,
I will provide you the link of a web page.
Please perform the same steps as given in the web page to get your issue fixed.
Please the web link given below.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00739528&cc=us&lc=en&dlc=en
Hope your issue will be fixed.
Ben Johnson
Marvin
Marvin
