Question about Apple iPod nano 4th Generation
Will not leave apple logo - Apple iPod nano 4th Generation
  • Apple Master
  • 27,725 Answers
Sometimes a iPod malfunction occurs that results in the Apple logo freezing on the screen of the iPod. When this happens, toggling the Hold switch or resetting the iPod typically resolves the problem. If following the manufacturer's instructions on resetting the device fails to get a response from your iPod, however, you must troubleshoot other potential solutions. In addition, taking the time to find the cause of the problem can help you prevent a recurrence of the issue.
Battery Allowing the battery to discharge completely may unlock an iPod stuck on the Apple logo. To drain the battery, leave the iPod with the Apple logo on the screen and place it in a drawer or in another safe place. Do not attempt to use the iPod until the battery drains and the screen goes black. This may take a day or more depending on the current level of battery charge. Once the battery drains, connect the iPod to your computer or to the wall outlet using an AC adapter and charge the battery completely before turning on the device. b> Restore If the iPod remains frozen on the Apple logo after draining and recharging the battery, you may need to restore the device to original factory settings. Unfortunately, this results in the loss of all data and media files stored on the iPod. Restoring the iPod, however, does not delete the files stored in the iTunes library, so you can still get your data back onto the iPod. Follow the specific instructions for your iPod model when restoring the device. Upgrade Software Problems with the version of software installed on your iPod may cause the device to freeze. Upgrading the software may resolve the problem because the updates released by Apple often include both bug fixes and software enhancements. In addition, installing the current release of the iTunes software also may resolve the freezing problem experienced by your iPod. File Corruption Often, a corrupt file can cause your iPod to fail. If you notice that the problem recurs after playing a specific song or video, then delete that file from your iPod. If the problem occurs again after synchronizing with iTunes, delete the file from your iTunes library. Then import the original file into iTunes again or re-download the file. Typically, if a corrupted file is behind the iPod freezing, a reset temporarily restores functionality until the problematic file plays again. b> App Overload Installing apps on your iPod touch can give you more than just fun or informative software. Running too many memory-intensive apps at one time can overwhelm the device and cause your iPod touch to freeze. A single problematic app may have the same effect. Limiting the number of apps running at one time or removing troublesome apps may resolve this problem.
b>
Posted on Feb 13, 2013
6ya staff
SOURCE:
I need help connecting to itunes because my ipod was disabled and i dont remember my password
ipod touch ? if thats the case you have to plug it into your computer using the usb cable.. open itunes and click restore ( it is then up to you if you want to add a password after itunes is finished. ) if itunes dose not detect the ipod or you are having trouble restoring it then make sure you have the most resent itunes installed then hold down the home button and power button at the exact same time and keep holding them. you will hear a ding sound and ipod will turn off,keep holding the home button but leave go of the power button when you hear the ding sound.now keep holding the home button untill you hear another ding sound ( this is the ipod powering back up but screen will be blank ) you can now leave go of the home button ( screen will be blank ) but itunes will see the ipod and say "ipod detected in dfu mode,you must restore " click restore ( if you leave go of the home button before the ding sound you will see the apple logo...if you see the apple logo you have missed the chance to get into dfu mode so do the steps again .. dfu mode is the best way to restore any apple device
Apr 29, 2015 | Apple iPod touch
Will not boot to safe mode imac g4
Starting up in Safe Mode Follow these steps to start up into Safe Mode.
  1. Be sure your Mac is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup sound, press and hold the Shift key. The Shift key should be pressed as soon as possible after startup, but not before the startup sound.
  4. Release the Shift key when you see the Apple logo appear on the screen.
After the Apple logo appears, it may take longer than usual to reach the login screen. This is because your computer is performing a directory check as part of Safe Mode.
To leave Safe Mode, restart your computer without pressing any keys during startup.
Sep 25, 2014 | Apple Computers & Internet
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
I pod nano2 apple logo blinking onlu how can i fixit
Maybe you can try leaving it in a cup of dry rice for a few hours, then charge it for a long while! Good luck!
[Also, yahoo answers might help you better]
Dec 06, 2012 | Apple iPod nano
After resting my unlock 3gs iphone , the phone frozen on apple logo.
Try holding the home button (one on the front of the phone) and the power button (at top of phone) down both at the same time until the the screen flickers off, then keep held down or repeat this until the apple logo reappears.
Hope this helps
(Please Leave Feedback)
Jan 06, 2011 | Apple iPhone 3G
My iphone gone blank tried press toggle and top button now has frozen on apple logo
Try pluging it into iTunes and hit restore. This should fix the issue.
I hope this answers your question.
Thank you for visiting FixYa for your solutions.
Susan
PS - Please be sure to leave positive feedback :0)
Apr 30, 2010 | Apple iPhone 3G
It's fully charged and had turned its self off, but wont turn it's self on again
connect the iphone to the wall charger. Hold down both the sleep/wake button at the top right and the home button at the same time. Hold both of those buttons down while iphone is connected to the wall charger, hold them down until you see the white apple logo appear. Once you see the logo, let go. It will take a minute or two, but the phone should be powered on and back to normal. Leave plugged in to the wall charger for at least 10 minutes before disconnecting
Dec 04, 2009 | Apple iPhone Smartphone
I cant turned on my ipod what can i do?
slide the hold switch on and off a couple of times and leave it at off position.press and hold menu and center button till an apple logo appears on screen..connect to itunes and restore.
Sep 05, 2009 | Apple iPod nano
80gig ipod
plug it into the computer, leave it for a few hours. mine did the same, so hopefully this should work.
Dec 27, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano 4th Generation Logo
57 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
