Able to insert dvd on side but how to start it playing
Insert a DVD disc into the DVD drive.
Open My Computer then right click on the DVD drive (it maybe the D drive) - click on Properties - then click on Autoplay..
You can try Leawo Blu-ray Player which contains all media playback solutions you need for your leisure entertainment, Blu-ray, DVD, CD, 4K, ISO image file and other popular formats supported.
You can check on this for how to play DVD on laptop:
My Laptop Won't Play DVD? Solved
SOURCE: slow processing and start up on thinkpad r61
sounds like you have too much data on your hard drive and possibly too much stuff starting up with your computer so use jkdefrag, msconfig, startup control panel and ccleaner to clear and clean up the data on your laptops hard drive.
Use ccleaner first which you can get here
and then defrag your hard drive afterwards using
jkdefrag which is here
msconfig you can access by going to start --> run and type msconfig and press enter or click on ok and then go to the startup tab and stop things running that you dont need to run although using startup control panel which is here would be a lot easier and better as you can check the run keys in the registry as well as the startup and run once keys and make sure only the things you need to run at startup are actually booting up.
Once you have done that see if it is any better and post back
SOURCE: Sound Driver
try downloading and installing the driver from here
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-63572
SOURCE: i upgraded the processor of my ibm thinkpad r51 to
The processor(CPU) frequency for computer work, it is the result of the frequency and the frequency of the product, the decision, doubling overclocking CPU is the best solution. But some manufacturer to prevent us, the CPU overclocking frequency lock (it confirmed the rationality, such as overclocking Intel most of the CPU is locked outside of, don't know you belong to the CPU does not belong to one of them.
SOURCE: hello i m not able to
Diagnosting tool: Lenovo Tool BoxDrivers: Lenovo Drivers
1. After clicking the link, select Networking: Wireless.
2. Select the Wireless driver that suits your operating system, Be sure of your wireless model. click the hyperlink in the middle.
3. Click the encircled portion.
4. After downloading click the executable driver, install and reboot if prompted.
5. After rebooting and problem persist download and install Lenovo tool box.
Kindly give a feedback if my solution helped you.
Thank you for posting.
SOURCE: Dear There, I have Lenovo ThinkPad
Two things. You might have a problem with the inverter or with the backlight lamp.
You need to open your Laptop Screen. Normally the screws are hiding underneath the rubber stops. It would be better if you can find a LCD disassembly manual for your laptop else just write down what and account everything that you do. Check for the Fluorescent like lamp if its burnt out. If it is then you need to replace that. If not, then you need to replace the Inverter(a long rectangular shaped circuit board. Normally it is just at the bottom of the LCD screen.) Note the product code written on the inverter and order it. This should fix that problem.
