Looks like a document jam as the paper rolled up under the scanner bed. If a multi-page document is loaded, remove Make sure the back end of the cover does
Do you have the manual for the unit?
It is on line at mypdfmanuals.com. Just google it!
1. Lift the document release lever.
the entire document from the ADF.
2. Lift the paper stack cover and pull it out completely.
not catch the front paper guide.
3. Lower the scanning platform in the document delivery slot (this is on ththe front of the machine - a small tab you push down.
4. Carefully!!! pull out the jammed document - do not wrench it out.
5. Lift the scanning platform back into place.
6. Inset the paper stack cover (that you took out earlier.
Found it here http://mypdfmanuals.com/dref/815752
SOURCE: Cannon I-sensys fax L100 - when I try to send a
press MENU and #, then clear , ALL, reenter all your sett. like number, tel line type,... it shoul do the trick
