Cm302 double wall oven
SOURCE: Thermador CM302 shuts off intermittently. No error code, timer remains working.
Dear Craig Buck,
This is either a fault with the timer, or you have a fault with the thermostat. Get a multimeter onto that thermostat and test it, after removing the heating element of course. Then get back in touch with me and I will give you the fix.
Yours sincerely
Ouszen
Most likely a bad relay board. Really just a couple of soldered pin points on the back of it are bad. If you are able to remove it (from the top) inspect each solder point and look very closely with a good magnifier for fractures around the protruding pins. Some are very difficult to see while others are plain as day. Clean gently with a pin or knife and resolder. Relay boards range from $200 to $400 in price.
