SOURCE: Carb on 2005 kawasaki Bayou 250
remover all plastic/ rubber parts
then soak the whole carb body and slow jet in lacquer thinner
the slow speed jet/needle circuit needs to be cleaned with just 1 strand from 18 gauge copper wire going through all passages an holes pilot circuit in pic
SOURCE: Yamaha 2001 Raptor 660, need to clean my carb
Drain and replace the gas with fresh.
Remove the air cleaner and spray carb cleaner into the inlet. Work your throttle a little then put everything back together and try to start it.
SOURCE: Hyosun Scooter Carb Adjustments
Very good thought process on the adjustments. The throttle screw sets the idle speed and the air screw sets the fuel mix at idle speed. The stock setting is 1.5 turns outward. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward.
From this point you adjust the idle speed then adjust the air screw for fastest idle speed at that throttle screw setting. If the idle speed becomes faster than desired after adjustment, just reset the throttle screw and then reset the air screw.
A “very helpful” rating for this answer? Thanks!
SOURCE: Air box and crank case fuel flooding problem
Well there only one way the fuel can get into the crankcase and that's from the fuel tank. The petcock must be draining and the float needles are not stopping the fuel flow. Do you have a prime position on the petcock? If so do not run the bike in the position. Try topping the tank off with gas and letting it sit for a while and see is the gas has gone down and then check the crankcase and see if there's fuel in it again. i still say its got to be your petcock.
Testimonial: "I will try it, thanks!"
SOURCE: I have a 03 Yamaha 660 raptor one of the carbs
Did you reset (adjust)the float inthe float chamber to tht carburator which is leaking ?
You will probabley have to adjust tht float to stop from overflowing in other words we call it flooding.
Check the float pin of wear at the tip.
Hope this helps!
I missed the small plugs that let fuel in under the large floats.
