Question about Opromo Kassel 15-day wood wall clock w/ pendulum, Price/piece
My clock chies 2 hours behind
My clock chimes 2 hour behind e,g for 3:00 I only get one chime
Posted by andyh666 on
UsedClockPartsdotCom
  • 277 Answers
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set. Fix Clock That Gongs Wrong
Posted on May 01, 2017
Yvonne
    Scholar:
    New Friend:
  • 53 Answers
If the clock is a mechanical clock there are 2 ways it can be fixed. You need to take the hands off the clock and gently replace the hour hand to the hour it strikes/chimes replace the minute hand and then gently clockwise ONLY move the minute hand to each hour letting it strike/chime the hour it is on. If this does not work there is another way and you can email me Yvonne. [email protected] for more information. Mechanical clocks only.
Posted on Mar 26, 2013
I have a Waltham Regulator Wall clock. It chimes 4 minutes late on the hour and 1/2 hour. How do I adjust it to chime on the hour and 1/2 hour? I've tried moving the minute hand with no luck.
Try this,remove batteries,set clock to 6 o'clock,reinstall batteries,then clock should chime,turn adjuster till you are at the right time,make sure your on am or pm,it doesn't chime at 10 pm- 5 am,so that will tell you if your at am or pm.When adjusting it will chime everytime you go past the hour.You can never go backwards,if you do then you will need to remove batteries and start over,use your phone's time to set.
Mar 15, 2018 | Chime Home
After spot cleaning mantle clock with German movement (circa 1960), the clock chimes properly on the hour but does not chime on the half hour.
I am hoping that you oiled it also? One trick I have found is to gently lift the hammers and release, sometimes the hammers will release and strike the chimes/gong. Do this 4-5 times and hopefully it will get it chiming for you again.
UsedClockParts.com
Nov 09, 2016 | Home
NEED DIRECTIONS FOR CHIME
clocks chime the hour
what is the point of having a clock that chimes every 2 hours because you will not know how long it was from the last chime or be able to calculate the time between chimes
Dec 28, 2015 | Watches
How do I get it to chime on every hour
most chiming clocks only chime on the hour from 6 am to 9 pm
if it is a digital clock with a chimer the set it to 12 hour and not 24 hour
make sure that the chime has a good battery in the chime circuit and it is set to chime on the correct hour
If the statement made to you was correct then it would be chiming at night instead of the day
Oct 13, 2015 | Home
I inherited a Seiko Westminster chime clock. The time is perfect but the hourly chimes are 3 hours behind. How can I synchronize the two?
Sep 21, 2015 | Seiko Mantel Clock
My clock chimes on the half hour and counts on the hour. It chimes 2 minutes late on each. How to I get the chime on the half hour and hour?
Get it to chime then loosen minute hand then move hand back to the 12 or 6 position tighten minute hand and test to see if that works
May 08, 2015 | Watches
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me [email protected] I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 | Watches
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Opromo Kassel 15-day wood wall clock w/ pendulum, Price/piece Logo
541 people viewed this question
Top Opromo Home Experts
john h
Tom Chichester
Are you an Opromo Home Expert? Answer questions, earn points and help others
