Question about Whirlpool LGB6300 Gas Dryer
My gas dryer will not blow air
Does my dryer have a component layout?
Posted by Brian Whaley on
Richard Gorenflo
    Champion:
  • 210 Answers
THis could be caused by a restriction in the blower housing,lint chute ,or exhaust. If you can not hear the fan running the bnlower wheel could have brohen or come off the shaft. You can access this by removing the rear panel and renoving the 4 screws in the lint chute.
Posted on Feb 13, 2013
2 Related Answers
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: my gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 06, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Posted on Jul 22, 2009
Samsung gas dryer--blows heat for a few minutes then blows cool air
the thermocouple ot high heat limiter ====the thermocouple when going bad -or not properly on bracket will shut the gas valve off --same with high heat limiter ---before checking these parts feel the air coming out if feels restricted clean the vent tube under the lint trap filter can use a vacuum from front and rear exhaust tube
Jul 14, 2016 | Samsung Dryers
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Dryer dosen't blow air
replace the blower belt and it will blow air from the dryer
Apr 20, 2012 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
The igniter lights. The gas comes on and ignites. The problem is the flames go out after less than a minute. I checked for lint build up and there was none.
I would look for air restrictions. Improper air flow will cause overheating. This will cause the components to shut down prematurely.themobilian_133.jpgthemobilian_134.jpgthemobilian_135.jpgthemobilian_136.jpg
If the gas fails to come back on then the gas coils are weak and overheating becoming intermittentthemobilian_137.jpg
Typical length of burn in a gas dryer:
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 13, 2010 | Dryers
Dryer not blowing hot air
When you say 220 gas dryer I'm not sure what you mean. If it's 220V then it should be an electric dryer, not a gas dryer. Troubleshooting is totally different between gas and electric. If it's electric (large 30A 220V plug) then good chance heating element(s) have gone bad. You can look up parts on www.searspartsdirect.com Have your complete model number. IF it's gas, it may be the pilot ignition has failed
Jul 26, 2010 | Kenmore 62602 Electric Dryer
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
My dryer works (spins, blows air) but it won't hea...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Dryers
My GE gas dryer is blowing cold air and wont blow hot air. what could possibly be the ploblem.
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 06, 2010 | Dryers
Dryer blowing cold air whirlpool awz3513
Check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about an inch long and is located just inside the rear of the dryer and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Aug 31, 2009 | Dryers
Kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Jan 22, 2009 | Kenmore 75962 Gas Dryer
Whirlpool LGB6300 Gas Dryer Logo
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
