SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
SOURCE: how do you take out and change the water filter on
At the bottom of refrig , on the toe plate , press the button on the left kinda hard , and the filter should pop out .
Testimonial: "thanks for the help. "
SOURCE: How do you replace the water filter on a
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
SOURCE: How do I replace kitchenaid superba KSCS25FKSS00
Here are some instructions for you.. it is important to press the ejection button and pull the filter straight out before turning counter clockwise..
1.Press the eject button to release the filter from the base grille. 2. Pull the filter straight out.
3.Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter. 4.Align the ridge on the cap with the arrow on the new filter and turn the cap until it snaps into place. NOTE: You can run the dispenser without a filter. Your water will not be filtered. Simply insert the cap all of the way into the base grille and rotate the cap until it is firmly in place. 5. Remove the protective covers from the O-rings.
6.Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
I hope this information helps you with your filter. They suggest
you replace the filter every 6 months. It could help the quality
of your water and if you make a lot of ice..
SOURCE: How to change the water filter on my Kitchenaid Superba fridge?
The details are on page 6 of this manual or I have pasted them below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202306982.pdf
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
3. Turn the cap counterclockwise to remove it from the filter.
4. Align the ridge on the cap with the arrow on the new filter and
6. Push the filter into the base grille. The eject button will pop
7. Flush the water system. See “Water and Ice Dispensers.”
