Question about Furniture
Hot paper plates stick to my kitchen table. I can't sand and refinish it because it is hand painted with designs. Is there a way to put a new sealer on it and if so, what do I clean it with dail
The table is 8 years old and distressed with hand painted flowers. I can't sand and restain it.
Posted by renee halpern on
Don Philippbar
    New Friend:
    Problem Solver:
  • 10 Answers
Sounds like a water based acrylic was sprayed on top and when the heat is added it makes the finish gummy . You can brush some polyurethane on top and that will make for a bullet proof finish.Put a little bit on somewhere and make sure it doesn't raise the old finish
Posted on Jun 28, 2013
1 Related Answer
ralph_father
Butch Fatherly
  • 43 Answers
SOURCE: I have a bamboo kitchen table and I want to paint it. What should I use?
Primer it first and find a good spray paint, once bamboo is dried out it dont take paint well
Posted on Sep 23, 2012
Hello I'm re staining outside wooden doors they been stained & polyurehtane like 8 years ago can just re stain and re polyurehtane
No. The original polyurethane must be removed completely by sanding down to fresh wood before restaining.
Nov 29, 2017 | Washing Machines
Tip
How to Restore a Picnic Table
After several years and a being exposed to the elements, your wooden picnic table can start to look really worn out. You don't need to spend a few hundred dollars on a new one - you can restore your old one. It's a project that will be both fun to do and save you money.
Where do I start?
1. Using a mixture of bleach and water (not too strong), scrub the table really well and leave it to dry completely.
2. Check the table for structural damage; hammer in any loose nails or boards and fill in any holes with wood putty.
3.
Now you need to sand the table down. Sandpaper comes in grain s of coarse through to fine. The worse state your table is in, the coarser sand paper you will need to start with. When you are finished, clean the dust off really well.
4.
Now you can paint or wood stain the table depending on whether you prefer a more natural look or a brighter one.
5.
Leave it to dry completely before using it. Enjoy your new table!
on Aug 20, 2012 | Garden
Tip
How to Fix Foggy Tail Lights in BMW 528 car?
1) Stick the masking tape and paper around the tail light to take care of the paint. 2) Take care nothing gets rubbed on the car paint or nothing gets scratched on the car light cover and paint. 3) Do it gently without any force. 4) Take a sand paper make it wet and use the wet sand paper to sand the tail lights. 5) Do this sanding until all the dirt and fogginess is removed completely. 6) You can use heavy grit sand paper if the dirt is very hard to remove. 7) After sanding is done clean and rinse the tail light. 8) After cleaning is done ,apply a plastic material polish cream on the tail light and gently rub it till the tail lights shine. This will help.thanks.
on Mar 18, 2010 | BMW 528 Cars & Trucks
My hot plate has bits of paint that came off. Still works great but the hot plate is unattractive, what can be done?
You will need to sand surface of where you are wanting to touch up so the new sticks -then use
High Heat - Spray Paint Can be purchased at most home improvement stores
Oct 02, 2017 | Cars & Trucks
This is a table top I have sanded down. I want to restain it. Is that possible. I'm not even sure what this stain is.
Staining a dining room table - YouTube
? 4:11
www.youtube.com/watch?v=guoS6wPi7ks
Sep 22, 2013 - Uploaded by Eric Wellington Staining the table that Dad and I made. ... Cancel Post. Topcomments. Top comments ... What kind of stain was used to get the table this dark?
Sep 29, 2015 | Washing Machines
Tip
How to Fix Foggy Tail Lights in Ferrari 348 Convertible car?
1) Stick the masking tape and paper around the tail light to take care of the paint.2) Take care nothing gets rubbed on the car paint or nothing gets scratched on the car light cover and paint.3) Do it gently without any force.4) Take a sand paper make it wet and use the wet sand paper to sand the tail lights.5) Do this sanding until all the dirt and fogginess is removed completely.6) You can use heavy grit sand paper if the dirt is very hard to remove.7) After sanding is done clean and rinse the tail light.8) After cleaning is done ,apply a plastic material polish cream on the tail light and gently rub it till the tail lights shine.This will help.thanks.
on Mar 18, 2010 | Ferrari 348 Cars & Trucks
Tip
How to Fix Foggy Tail Lights in Avanti Convertible car?
on Mar 18, 2010 | Avanti Convertible Cars & Trucks
Paint will not dry
Could be the paint you're using was old, sat around too long and was not properly stirred, before applying? or did you apply multiple coats without waiting enough or too long in between? You will have to strip all the paint off using a chemical paint stripper. Then wash off all the stripped with the proper solvent, then wash off the solvent. Make sure the wood is totally clean. Then sand lightly to open the pours of the wood. Apply one coat of primer, let dry, then apply as many coats of paint as you want, just make sure its dry between each coat, etc..
Aug 26, 2014 | Tools & Hardware - Others
Unable to remove old door handle for Baldwin 5255 lever
They are usally pressure fitted, however paint on the door it self will make it stick.
Take an sharp utility knife and score the paint as tight to the
escutcheon as you can, then it should pry off.
Feb 01, 2014 | Baldwin Wave Left-Handed Entry Lever...
I have decided to distress my old dining room table to give it a vintage look. What do I need to get started? Will this be hard to do?
Distressing wood is not a difficult task. It is quite simple and can make a boring old table look interesting again. Here is a how-to guide that will take you through the process.
http://www.ehow.com/how_4882264_distress-wood-table.html
Aug 09, 2012 | Furniture
Furniture Logo
1,500 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
