Question about Apple iPhone4 4G iPhone 4
How do I open an attachment that says "Shared_Cards.tar
Posted by Teresa Buhl on
How to install a back glass in a 05 dodge magnum wagon. The back lid glass
If you would please look at the glass and the metal door in which it attaches, I believe you will see there is a black "tar" that holds it in place.
First, disconnect the electric rear window defroster wire, if you have one.
You would, using a very thin steel wire, separate the glass from the "tar".
Then, clean the tar out of the channel, and prepare the rear door for new tar and the new glass.
It sticks on.
Nov 09, 2015 | Dodge Cars & Trucks
Tip
How to back up a Tape in Linux operating System
<p>Linux is a free operating system based on Linux kernel and provides a UNIX-like interface. Several Linux distributions including Ubuntu, Debian, Fedora, Pacman, RPM, Gentoo and Slackware. Linux is used in games consoles, mobile phones, netbooks and computers and mainframes and supercomputers. The Linux system can be through a Command Line Interface (CLI) or a graphical user interface (GUI) control. When you save data on your hard disk, a tape on Linux a few steps required to configure. <br /> <p><br /> <p>1. Open a terminal in Linux, and enter this code to data on multiple tapes: <br /> <p> <br /> <p>Tar clpMzvf / dev/st0 / home. " <br /> <p>2. Enter this code to the backups to compare: <br /> <p> <br /> <p>Tar dlpMzvf / dev/st0 / home. " <br /> <p>3. Restoring all backups missing hard disk with this code: <br /> <p> <br /> <p>Tar xlpMzvf / dev/st0 / home. " <br /> <p> <br /> <p>Now you have a tape backup done on Linux. <br />
on Jun 22, 2011 | Computers & Internet
Tip
How to install programs in fedora linux
- you have to have the program in one of two forms of files either .tar.gz or .rpm.
- if you have the program in the rpm format you need to open a terminal window, then go to the file location, then type: rpm -ivh "file name"
- if your have the file in the compressed format .tar.gz, first of all you have to decompress them using: tar -xzvf "filename.tar.gz"
then go to the produced folder after decompressing, search for a text file named INSTALL, and follow the instructions..
on Sep 15, 2010 | Computers & Internet
When i boot up my Dell Latitude D420 laptop it just doesnt show anything, not the log on window or anything
No display could be the ram needs to be reseated.
They use shared memory and if the memory cards get knocked loose=No video.
Aug 25, 2011 | Dell Latitude D420 Notebook
Tip
HOW TO INSTALL FROM SOURCE IN LINUX
HOW TO INSTALL FROM SOURCE IN UBUNTU 9.10
Installing from source in linux is not very easy...... but once you know what to do, then it becomes a very easy task.
STEP 1 Tar.gz and Tar.bz2 Packages
The installation procedure for software that comes in tar.gz and tar.bz2 packages isn't always the same, but usually it's like this:
1.Download the tar.gz or tar.bz2 package
2.Extract the file
3.Open to the terminal
4.Use the cd command to change to the directory where the package is extracted
5.Use the following:
$ ./configure
$ make
$ make install
Without Using The Extraction Method
Run the following:
$ tar xvzf package.tar.gz (or tar xvjf package.tar.bz2)
$ cd package
$ ./configure
$ make
$ make install
!!!!THIS IS AWESOME!!! …... ISN'T IT?
STEP 2 .Deb Packages
Installation of .deb packages are in different forms or methods depending on the users understanding and how the user is flexible with the terminal.
1.Download the package
2.Extract the package
3.Change to the directory containing the package
4.Run the following
sudo dpkg -i package_file.deb
!!!! AND YOU ARE DONE!!!
LINUX X64 AND X86 BINARY INSTALLATION
2.Open to the terminal
3.Use the cd command to change to the directory containing the package
FOR X86 PACKAGES.........
$ chmod +x filename-ver.*-linux-i686.run
$ sudo ./filename-ver.*-linux-i686.runFOR X64 PACKAGES........
$ chmod +x filename-ver.*-linux-x86_64.run
$ sudo ./filename-ver.*-linux-x86_64.run
where ver is the version number (the whole number before the decimal point... eg; the 4 in 4.103)
!!!!THANKS A LOT!!!!
on Jul 21, 2010 | Computers & Internet
I have the SmartDisk PhotoBank 80GB and it will not read my cards. I reformatted it and I can drag pictures onto it. They open fine but it simply will not read my cards.
The SmartDisk PhotoBank will not read cards above certain capacities (depending on the type of card). For example they will not read SDHC's etc.
If it won't read any cards (and it use to) then you may have a problem with your driver as I had such a problem. If this is the case please see below. (N.B. always best to back-up and/or create a restore point before updating drivers etc.
This solved my related problem...and it may solve yours...please let me know if it does...
I had a similar problem (probably caused by deleting files within the device folders on my PC) and have searched tirelessly for a solution and had pretty much given up until I stumbled upon a link to the site below.
http://www.box.net/shared/i8dknblsuy#/shared/i8dknblsuy/1/25549066/265225700/1
SmartDisk_FAT32_tool.exe (392.0KB).
(Sorry don't know how or indeed if 'allowed' to attach files etc.)
I was dubious at first with so many previous false dawns and especially with concerns about security. Although I can't personally vouch for the site, the link or the downloads integrity, McAfee gave the site and links a 'green' bill of health, the laptop is still functioning fine and as it should (nothing malicious detected by various security software such as McAfee and Spybot S&D etc and most importantly the SmartDisk PhotoBank is once again fully operational; all in an instant with no ill-effects or anything untoward occurring.
KR
DIMDIY
Dec 28, 2010 | SmartDisk PhotoBank USB Digital Dr 80 GB...
Mionet problem
Your account has something called "account bug"
You will need to reinstall MioNet on all computers, reset the My Book World, then attach it to your new MioNet account. You'll need to download the Blue-Ring My Book World version of MioNet here:
http://www.MioNet.com/mbvista
Then, to attach your My Book World to the new MioNet account (just select a new username when you re-install MioNet), follow these directions:
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
You should now be able to sign in to the Shared Storage Manager as admin/123456.
5. Please open your web browsers and enter (without the quotes) "http://<IP address of My Book World>" or "http://mybookworld" in the address bar. The Shared Storage Manager web page will appear.
6. Once you have accessed the Western Digital Shared Storage Manager please select "General Setup" then choose "WD Anywhere Access settings." Use the default username of "admin" and default password of "123456" (without the quotes). On the following page you will have three buttons to select, please click on the "Reset" button. This will return the MioNet software on My Book World to default settings.
7. From within the MioNet Client, go to File > Remove Computer. Locate the My Book World (WDStorage, MyBookWorld, or whatever you named it) and remove it.
8. If you do not see a new window from MioNet informing you that you have a storage device available, "Scan for Cameras and New Devices…" to detect the unit.
Jul 16, 2009 | Western Digital 500GB My Book World...
I can't access my drive through mionet. My son accidently unplugged the world book and I can't access it ever since. Should I reinstall the mionet. I can't remember if there were any installation CD that...
Once the My Book World has been plugged back in, it will request a new IP from the Router. If the drive was unplugged accidentally, the ethernet cable may have also been knocked loose: make sure all cables are attached to the Router and the My Book World.
If your drive is still not appearing properly in MioNet, you can do a Hardware and Software reset on the drive. It will not affect your data, and it will allow you to re-attach the drive to your MioNet account. You do not need to reinstall MioNet to do this.\
Jun 11, 2009 | Western Digital My Book World Edition 1TB...
Apple iPhone4 4G iPhone 4 Logo
117 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
