Worked out off the box .put in my address and that's the last time it worked
SOURCE: GPS Won't Turn On
I suggest any unit under warranty to be returned to its supplier or if they will not help, contact tomtom directly!
http://www.tomtom.com/support/index.php?Lid=1
Download the latest updates from tomtom.
SOURCE: The reset button does not work?
Hello :
Try first to update the software of your GPS . If that didn't solve the problem and since the button doesn't work I advice you to take it to the service for repairing .
good luck .
rate please !
SOURCE: BLANK SCREEN BUT GREEN LIGHT ON
My guess is the wires that come from the screen and plug in the circut board have been jarred loose they my be all the way unplugged and just cocked to the side. if you r brrave enough to open it up its a easy fix. or you could send it to garmin and pay a couple ben franklins to have them fix it. either way good luck
SOURCE: Hi, I have a TomTom
Hello!
First remedy is to check if the battery is faulty. Charge the Tomtom GO 910 fully. Then, there is a small hole located under the the unit close to the
connector that you can insert a needle or a paper clip to reset the
910.Take out the sd card for some time before putting it back. Turn on your unit and see if it response.
If nothing happens to the first remedy, then the problem is with the hdd of the 910. Replace the hard drive of your Tom-tom. It will be risky if you do it yourself, you might inflict further damage. It might also ask you for the activation code. But if you are willing to do it and you have the replacement hard drive, check the links below:
1. How to replace hdd of Tomtom GO 910
2. How to disassemble Tomtom GO 910
