P - 26 1st image transfer ATVC black failure
P - 27 2nd image transfer ATVC failure
P - 29 1 st image transfer ATVC colour failure
Check the transfer belt unit contact and that of high voltage board for connection and clean or correct the contact.
Change the image transfer belt unit.
Clean the sensor windows on the transfer belt unit.
ACTIVITY REPORT
The FAX is factoryset to automatically print an ACTIVITY REPORT after every 20
transactions. If you want to print an ACTIVITY REPORT before it is automatically
printed, follow this procedure:
Transactions in an ACTIVITY REPORT are listed chronologically.
1 Press Function.
2 Press Report.
3 Press OK.
• The FAX prints an ACTIVITY
REPORT.
• If you prefer the FAX not to print an ACTIVITY REPORT after every 20 transactions,
disable the ACTIVITY REPORT setting ( p. 145).
• Please note that only one transaction number (TX/RX NO.) is assigned when you send
a document to several fax numbers in one operation.
ACTIVITY REPORT
PRINTING REPORT
27/12 2002 15:00 FAX 123 4567 CANON 001
ACTIVITY REPORT
ST. TIME CONNECTION TEL CONNECTION ID RESULT
* 27/12 13:43 905 795 1111 Canon CANADA 5001 AUTO RX ECM 1 OK 00'33
* 27/12 13:45 905 795 1111 Canon CANADA 0001 POLLING RX ECM 0 OK 00'00
0 STOP
* 27/12 13:51 03 3758 2111 Canon TOKYO 0002 B'CAST ECM 3 OK 01'18
* 27/12 13:53 2 887 0166 Canon AUSTRALIA 0002 B'CAST ECM 3 OK 01'18
* 27/12 14:10 905 795 1111 Canon CANADA 5002 AUTO RX ECM 1 OK 00'18
* 27/12 14:16 2 887 0166 Canon AUSTRALIA 5003 AUTO RX ECM 4 OK 03'59
* 27/12 14:27 20 545 8545 Canon EUROPA 0003 DELAYED TX ECM 1 OK 01'20
27/12 14:30 20 545 8545 Canon EUROPA 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:31 03 3758 2111 Canon TOKYO 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:57 2 887 0166 Canon AUSTRALIA 0005 TRANSMIT ECM 3 OK 01'25
0 STOP
27/12 14:59 1 432 2060 CANON OPTICS 0006 TRANSMIT 0 OK 00'01
0 #018
go to this site to download manual (see page 11-3)
http://files.canon-europe.com/files/soft30110/manual/FAX_L220_L295_UG_ENG.pdf
